Hi Aaron,
Do you still have the PDF available for download?
Steve
Bedini SG
new thread
Hi Seph,
Feel free to start a new thread anytime in the appropriate forum.
The reed switch is just experimental... I can't say if it is improvement over bedini's patent or not. The relay is supposed to pulse the charge collected by the caps into the charging battery.
But I can't really comment on this set up in this thread since it isn't an SSG so I started a new thread
I don't think the Energetic Forum has a thread for the Monopole Energizer either We have one for the Schoolgirl motor and the SSG but not the full set up as specified in the patent...
Admin, Aaron and All, if it is alright with you I might start the thread.
Hi Seph,
The youtube video is great!
Could you post your schematic here and explain the reason/purpose of the reed switch and relay?
If you have a bedini SSG with a triger coil then why the reed switch? What is pulsing the relay?
This set up looks very interesting..... can I use a Hall Effect Sensor instead of a reed switch?
Thanks for the excellent new experiment.....
Todd
Originally posted by Sephiroth View PostI am so extremely excited about my new monopole my hands are shaking!!!!
I'm just going to go run round the room screaming yahoo for a little while then I'll be back!
Watch this space!
As a taster I think I have found a way to convert the SSGs output into pure longitudinal waves and the difference in behavior is extraordinary!
Tesla, I love you!
Testing coils...
Originally posted by Guruji View PostThanks theremart for response.
When you told me check resistance does it mean that I change the trigger resistance?To higher or lower?
Yes I'm using neos.
How can I check the second coil cause I don't know if it's giving bemf with the other?
I unsolder the connection to E of the second transistor and fully test out the first curcuit before I move on. A small step at a time I have found works best for me.
Mart
multicoil
Yes I'm using neos.
RE: Multi coil.
Originally posted by Guruji View PostHi guys any help please?
I build bedini multicoil schematic with 100ohms bases on the two transistors.The thing is that now the rotor stopped and primary coil is singing.
I asked in several forums and it seems that no one knows the answer.
Any help please?
Thanks.
Check the resistor on the base trigger coil. Are you using neos? If you are you may want to back away from the wheel.
May be best to go down to only the primary coil and work out. Best to do one coil at a time till you sort everything out.
Mart
multicoil
Any help please?
Thanks.
John's comments
Hi Druide,
That pdf was some pasted messages from John Bedini.
The messages were originally posted in a private group.
John then posted the private messages for the world to see in
the Bedini SG group.
The place I copied the messages to put in the PDF were in the
public Bedini SG group...therefore, they are no longer private posts.
The private group mistakenly believed I was posting the private group's
private messages so I yanked it because I first thought that I might
have done it by accident. I checked the messages and they were all
messages I copied out of the Bedini SG group that Sterling had.
If you want these posts, simply go to this group:
Bedini_SG : Messages : 10978-11017 of 11017
It has been closed down since March.
Search for posts by John_Bedini. The posts in this pdf were in the last
few months of this group directly from John. There may have been 3-4
posts from other members that had good posts in response to what John
was typing and pasting over from the private group.
He posted some from the OTG group (off the grid) so if you see reference
in that Bedini SG group, those are posts he wanted everyone to see.
The pdf was almost 100 pages so that is lot of copy and pasting. Anyway, just check all of John's messages probably from Dec 07 to the end when
group was closed.
Broken Link
Originally posted by Aaron View PostFor anyone who has not been involved with the Bedini SG group that was recently closed, I compiled the messages from John Bedini as he was posting them. I only have this from The end of Feb until a few days ago and it has a lot of valuable information that he has never really discussed openly before.
This link is the PDF: John Bedini SG yahoo group comments , it is 91 pages
It might take a few hours to go through this, but if you want to learn about the SG, it is best to hear straight from John.
Tried to download the PDF file but it seems it's no longer in the library. Aaron, is it possible to put the file back in the library ? Thanks.
Thanks to everyone for sharing all this information !
Keep on sharing open source engineering !
Druide
More,More,More
Watch this space!
Tesla, I love you!
Ok,What is it you stumbled upon.Give us some more info,After your heart returns to a normal pulse of course .
-Gary
Watch this space!
Tesla, I love you!
Look this way for extract some mechanical torque from Bedini SG.
I can upload the video so, I'll explain yours...
It's easy, I think possible yours did made this test. I don't know.
Simply in output put a Big capacitor with a DC motor.
Run very well, obviusly depend the size if is very big no run....
But torque is relatevely good.
Originally posted by theremart View PostNo you do not...
You can do like I did let the charging battery slip off and then replace 6 transistors.
Today each of my transistors have neons...... it does pay to do it.
Mart
To Neon or not the Neon
Originally posted by Guruji View PostHi guys when doing multicoils one has to do a neon for each transistor?
Mart
