Bedini SG
  • ren
    im not too sure what or if it offers any advantage as yet, besides the primary drawing less. It slows down rotation, but allows you to use alot less trigger resistance. For example. I ran my trifilar perspex rotor on full resistance @ 24 volts and amp draw is 200ma +. With the cap in place it drops to less than 50 ma and I have to decrease resistance to find the sweet spot again. Dunno if it will actually amount to anything, just interesting.
  • Jetijs
    and how this changed the RPM's?
  • ren
    just a little something I found interesting guys. I put a small uf rated cap between the base and the positive of the run battery and the amp draw dropped. Interestingly enough the voltage on the cap is higher than the battery??
  • theinventor
    here is the schematic
    here is the schematic. sorry i forgot
  • theinventor
    need help with power coils and trigger coil
    What kind of reed switch in particular would be an allaround good r.witch to use for the ssg's?
    I need to know if this (the bedini monopole radiant mechanical oscillateor Charger) uses 2# 22's (power coils) and 1# 26 (trigger coil).
    Obviously, this is a tri-filar coil i just need to make sure of the sizes of the coils will some one please enlighten me?
    Thanks for yas help!!!
  • Runnningrage
    I figure out my 12v small capcaity primary battery is dead
    Can charge (1.3A12-1.3F 12v 1.3Ah AGM Sealed Non-spillable battery) with your car
  • Chip Shorter
    If you really want a good charge replace the transistor and its driver winding with a reed switch. Leave the big diode in. Once you get the timing right you will see some cool stuff.
  • Runnningrage
    Maybe it the length of wire
    When i researching on the bedini motor i want to have the best result. Even
    if it was a beginner vision of the motor. I was told to make the wire a short a
    possible. I hate to unsolder the wire again. First i going to switch the resistor
    see if that help guys but it that false make wire longer. Nice quote Jetisjs;
    even invention has it errors it's a test for the person who building it. To endure it with patient so it can reveal it secrects to you just like NIKOLA TESLA.
    Who has seen the movie the Prestige. I was watching the movie Prestige the other day. Were David Bowie who played Nikola Tesla. The machine had have
    many errors with the machine but if could harnest the power of machine it reveal its secrects. The bedini motor has it own secrects too charging many
    batteries just running on one. Multiplication it reflect the same pricipales as the Nikola Tesla machine coping a man infinity amount of time. When batteries
    are expose to this type of power you conduct electricity through uncommon materials like plastic. Where in the movie Tesla
    demonstrated electricity can run through man without harming him, and power a load like a lightbulb. If we keep doing research on these bedini motor more,
    more, secrect are going to come out. Then the world would know what they been missing.
  • Sephiroth
    Hi RunningRage! Good to see you here!
    Have you managed to achieve rotation or are the batteries/transistor heating up as soon as you connect them?
    Jetijs and gmeat are right, your resistance is WAY to high but that shouldn't be causing the batteries to heat.
    Are you sure the emitter and base are the right way round? with the poles closest to you the resistor should be connected to the right hand pole. (I made and error at one point at the end of my video where I accidently flip-flopped the schematic )
  • Jetijs
    Too much resistance on the transistor base should not get the batteries go warm. Sounds more like a short, that could be due to a fried transistor. Doublecheck your wiring and try a new transistor. Do you have a neon bulb across the emitter and collector of the transistor? DO NOT power the thing without any charging battery attached. Also if your batteries are going hot, try to measure their voltage before and after a quick test, this way, if the voltage after the test is considerably lower, then you got a short in the system, probably in the transistor. If it was a dead short, then your wires should get hot very quickly and the insulation would start to melt (you would smell that). But if your transistor is dead, it could let some moderate current to flow through - big enough to get the batteries to heat up, but small enough to leave the wires in tact. I noticed the same problem when I blew up one of my SSG transistors - it would not switch but instead let the current directly through, like a closed switch. In my case it was about 4 amps of current draw. If you had a direct short, there would be a lot more amps flowing and melting all the wiring
    So I bet on the transistor.
    Hope this helps.
    Jetijs
  • Runnningrage
    Thank
    Thank gmeat you have built on of the motor did you have problems with it before or every heard some have this much troubleshooting
  • gmeat
    You have to much resistance
    Hi Runnningrage,
    Try to lower your resistance value.I would suggest eliminating the 1 megohm pot completly.Basically you have to much resistance and want around 680 ohm to begin and adjust up or down from there.Hope this helps
    -gmeat
    p.s. You should delete your post in electric motor secrets thread to save yourself a flogging from Peter as that thread is strictly for his motor design ideas.
  • Runnningrage
    I just bulit the entire thing today but nothing happen. A bad sign is the batteries
    are getting warm so something definetly wrong with it. i have good background
    knowledge on the bedini motor but still something must be wrong with. If you
    can give me some advice ,or maybe i can send u some pic if u can point some
    thing out on the pic i going to send u would greatly be please. Didn't want to
    solder all of my connection so instead i used alligator clips. Just in case i want to
    replace my transistor. I don't know if it matter i solder all of the connection are
    not. I want so bad to make the motor run, but the trobleshooting is me making so
    upset.
    My the parts i pick are the source of the problem here is a list of them
    - Power Battery (werker wka12 1.3F 12v 1.3Ah Lead Acid)
    - Charge Battery ( YUASA 12V NP2.3-12 2.3Ah)
    - Potentiometer 1-Megohm Liner-Taper
    - Transistor 2N3055
    - Resistor 10K-Ohm 1/2 watt 5% tolerance
    - Diode 1N4007 1000V & 1N4001 diode
    - Alligator clips for connection expect transistor i solder 1N4007 & 1N4001 diode to the Base with Emitter and collector
    -Magnets are facing north
    The coil doesn't turn to a eletricmagnet i connect the batteries to it, but it's suppose to arract the magnets to the electricmagnet coil
  • Runnningrage
    "help Wanted"
    upset.
    - Transistor 2N3055
  • Sephiroth
    Message from Lee to Sephiroth regarding relay coil in the trigger circuit:
    Hello Sephiroth,
    I have been working on a video presentation regarding my forwarded post to the energetic forum.
    Congrats on you demonstration video!! The choke in the trigger winding clearly has a benefit in your set up. Unfortunately, what works for one person may not work for the next, this is the problem with home brew SSG's. Anything that reduces current draw on the front end while maintaining the same charge rate, more or less, is certainly a modification in the right direction.
    As you will see in my video, when I get it finished, my RPM was reduced. The single coil unit I used to demonstrate your experiment was already well balanced regarding magnet spacing and coil construction. Also, the only inductor I had with enough inductance to make a difference was the coil of a 12v relay. This relay had quite a high resistance in the coil due to the fact that it had a low holding current, around 30mA.
    What the video does show is the affect your modification has on rotor timing and transistor duty cycle in a very visual manor. My setup may have shown the effect to extreme, one of the problems I had with big coils around very small light rotors was rotor runaway, sometimes it is beneficial to introduce a small amount of drag and, on the other hand, sometimes it isn't.
    I can only suggest that you engage in some load tests to see if the choke in the trigger improves battery charging efficiency relative to energy input. It's important to take relative measurements as you could miss a percentage increase at a lower energy input and miss it because your batteries "seem" to take much longer to charge.
    Kindest Regards Lee....
    PS. Feel free to re post this to energetic if you wish. I joined over a week ago but I'm still
    What he says has got me thinking... even I would expect the rpm to be lower with shorter pulses so perhaps it is something about my motor which benifits from the relay coil...
    I think Lee may have found the answer. Possibly because my rotor is very light, has a small diameter, little friction and three coils the torque/wieght ratio is so high it goes into "rotor runaway"... and of course the amp draw generally increases as the rpm increases.
    The shorter pulses reduce the torque (as indicated by the slower acceleration) to a point where less is wasted. So it is more efficient.
    SO.... new challenge. I want to add drag to the rotor in a way that will provide extra charge to the batteries... tried adding a few coils around the perimeter of the rotor but they only charge the cap up to 6 volts so need bigger recovery coils... will let you guys know if anything interesting happens!
    until then, I think this is still a pretty good modification for small rotor ssgs...
