Originally posted by Slinky
Bedini SG
Quote:
Originally Posted by Slinky
I couldn't reproduce this mornings fierce purple and white neon flaring up whatever I tried, perhaps leaving it primed but not spinning last night had some effect I know the neon is for safety and a tuned system doesn't need it but this was a very different effect to the neon glowing at high resistance.
I tried to show a friend who popped over without success and felt like a fisherman exaggerating how big his catch was.
Anyone know what I mean? I badly want to reproduce it and grab some macro shots.
Originally posted by tjnlsn255 View PostGreat rotor.... looks awsome for a Bedini Window motor.....
You can probably drill out the ends of the shaft and thread the hole to whatever size and thread you like.... that would be easy.....
What are the materials it is made of?
Hopes and Dreams....
Tj
6" x 2" rotor is made of aircraft aluminum and has stainless steel shaft, but the shaft is huge. I'm worry it may interfere in working setup. It wont bend, for sure
Vtech'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
General D.Eisenhower
http://www.nvtronics.org
Originally posted by blackchisel97 View PostNow I have to figure out how to modify that in simple way to be useful for my project. I'm tired of working with people around
Originally posted by sucahyo View PostThat is sad news. How about tying the magnet with car fanbelt at side? to leave some gap in the middle. usually fanbelt available at various size and it is very strong.
Originally posted by blackchisel97 View PostThe rotor itself was done well. Magnets slide from the side since the slots are slightly tapered and will be epoxied as well. I'm just unhappy with the diameter of the shaft, fastening nut and lack of flange. I think I'll ask them to cut off most of the unthreaded part and make a round flange threaded inside which can be fastened to the vertical part. I'll need a 1/2" or less spacer between the wall and rotor side too. Just got home and have to get few things done, including pyramid modification (have some interesting observation with use of crystals - will post in pyramid thread later), multistrand for my solid state, start assembling cap pulser and couple more, if time permits.
Vtech
blackchisel97,
I am green with envy I would love to build a SG like you are.
The problem with your shaft is dissapointing to say the least, all I can think of is maybe to use bearings that fit the rotor hole that have a smaller diameter central hole "the size you want" and have a new shaft made.
Originally posted by Farmhand View Postblackchisel97,
I am green with envy I would love to build a SG like you are. I feel the same watching 10 coiler running on others benches. I couldn't find anyone locally to make a decent rotor for a while. After several builds based on large hard drives, pulleys and bike wheels I was finally able to save a $ to order this one. I have enough wire to wind 2 coils at most and enough transistors for such. Remaining 4 will have to wait a bit
The problem with your shaft is disappointing to say the least, all I can think of is maybe to use bearings that fit the rotor hole that have a smaller diameter central hole "the size you want" and have a new shaft made. You gave me an idea Leave those bearings, since the work very smooth and use a spacer tube in inner hole to accept thinner shaft. Still need a flange to be made.
StarShip Bedini
Originally posted by Farmhand View PostThat will work too, good thinking, can't wait to see it spinning.
Oh my goodness that is incredible, is it "just a coil" though, it's magnificent. I think it's more than a coil it's almost working art. The wavefrom is neat. And it's charging that battery good and proper. I can't imagine how a thing like that is made, I have trouble winding four wires on a spool and keeping it neat.
Awesome.
Originally posted by Farmhand View PostOh my goodness that is incredible, is it "just a coil" though, it's magnificent. I think it's more than a coil it's almost working art. The wavefrom is neat. And it's charging that battery good and proper. I can't imagine how a thing like that is made, I have trouble winding four wires on a spool and keeping it neat.
Awesome.
Another Starship experiment
Originally posted by blackchisel97 View PostI want to try another pattern tomorrow, trifilar and see if I can wind one wire -180deg. I wonder if this may allow me to pull something useful without other coil noticing
Update: I used litzed coil in "normal" bifilar self oscillating configuration. Waveform is nicer than my other coil and spikes are at 55V. Circuit oscillates at 10kHz and is charging well.
Originally posted by Farmhand View PostNice, I wonder have you thought of placing an inductor "with core" into the middle of your starship and measuring the voltage across the ends of the winding ? I wonder what is going on in there. Mindboggling
