Hehe, yeah it go's up to 12 000 with new bearings it's a bit of a laugh really, at 10 000 rpm thats 166 revs a second, the rotor is 50mm, so the magnets are traveling at about 26 meters a second. I'm very surprised the magnets haven't come off yet. I glued them on with hot glue.
If the rotors not balanced good it ruins the bearings and won't spin so fast. It runs on up to 30 volts which kinda surprised me. Best charging is at about 7500 rpm .
There are three power coils, but only one trigger coil, each power coil has a transister and there has to be identical resisters from the trigger winding to each transister base as well as the original pot and fixed resister, I have the fixed resister jumpered with a switch for fast spinup.
There is probably a circuit drawing somewhere in this thread for multi coil SG.
Oh there is a generator coil at the top of course just to see if it would work.
I'll see if I can find a multi coil drawing and post it here.
P.S. You could quite easily make your's into a two three or four coil SG. one that size would probably spin up to a sweet spot somewhere between 2 to 6 thousand rpm, and would work very well. but you need to make sure the magnets don't come off a bigger one like yours, mine has soft linolium type magnet strips, so i'm not too woried about it.
![Big Grin](http://www.energeticforum.com/core/images/smilies/biggrin.png)
