Charging with radiant charger is never near that hot even at 0.75A, maybe because the charging voltage is much lower. The battery is even cooler than when being runned. Let see if the battery got less life. - You can cold boil your battery and ruin it. When charging with radiant there is no heat. Heat means energy leakage and loss (unless you want to transform electricity into heat). Still, C20 should not be exceeded.
There are also 15minutes charger available. I think it charge more than 1 Amp. - They're battery killers This is huge, very profitable industry, especially non-rechargeable batteries.
Can you really charge a Lithium with Radiant charger? Isn't Lithium cell will be damaged if exposed to high voltage and radiant charger has HV spike? - yes but not with HV pulses such as from radiant charger or solid state. I charge 2300mA AA's but I use one of my small SSG's.
Vtech
Vtech
