bigger coil
Hi Dann
I have built several SS devices in the past 2 years. What I found is that the coil needs to have low impedance. I wound tri filar coil with 100 ft of AWG 18 - like a 1:1 transformer and tried both, normal and inverted trigger. Inverted gives me better charging with lower input. Circuit will start to oscillate at 3V IN which is great if one wants to use a solar panel. It will charge with v. low light! I adjusted trigger withe a help of a scope to see the wave. I put 12V5W automotive bulb in series with 1k 5W pot and trigger. Trying to keep bulb from glowing bright. Circuit draws near 2A at 9V. I just restored 3 small LAB's and working on bigger 1000CCA. Circuit works great. I'm charging off the bridge with 4uF DC cap across. If I take a clamp off the batt. terminal for 1 sec. potential exceeds 600V. Output wires need to be short and good size to lower impedance. I cut open one of the batteries and was able to see what's going on inside. Not everything can be seen
Vtech
Vtech
