Originally posted by pvar06
I stop doing direct radiant charging now because I want to see how long a relay can last when used for cap dumping charging. Charging definitely much much slower than direct charging since the cap being dump to the battery in 2Hz frequency. 15 minutes passing and don't see an increase in voltage yet. voltage raised from 12.5V to 13V in 2.5 hour.
If I don't see voltage increase in two hour I will go back to direct radiant charging.
Maybe TIP122 is not a switching transistor so it won't give radiant output if driven with non sharp signal.
