Bedini Capacitive Discharge Chargers
    Is there a reason you want to use a relay instead of an SCR?
    Thanks Aaron.
    Seems the SCR is staying opened after the cap reaches some voltage.
    I have zener 16V along with a led diode to trigger the scr and the led lights all the time ... it is dim though. The cap bank is ~70mF and more have arrived to make it ~130mF.
    I have tried also neon controlled SCR, transistor breakdown.
    I think you mentioned earlier that you got best result with mechanical switch. So I want to try this.
    I am using different methods to charge the caps, bedini style PC fan, SS SSG, joule thief (currently). I am experimenting and learning basically as I am not an electrical engineer.
    Now that I am writing this I got some ideas what I might have done wrong. So I will post later.
    My relay is of this type
    https://cdn.shopify.com/s/files/1/09...g?v=1446834758
    • cap dump
      Here is one old version I did:
      Bedini's patent cap dump without scr -
      Older mechanical switch timed by pulley using isolated recovery winding:
      RPX & MWO http://vril.io
      • Thanks Aaron.
