RE: heat.
Ok not sure of your setup but I would agree the longer the on time the more amps are hitting the transistor. I am mainly only teasing my setup putting in 1/4 amp at 40 V I have not hit it with a large amount of amps of yet. But Jetjis had great success with that amount of amperage I may charge up two batteries then try them at 24 V at 4 amps ... Have been too scared to try it as I love my working setup
But at first I did have trouble with heat, both in my coils and my transistors but then I added even longer coil seemed to help things out alot in terms of heat.
I am in no hurry to charge up my Semi battery so 2 days to get to 13 - 14 V is fine. I am still working out some of the issues getting the solar panels hooked up right. They are rated at 130 watts, I should be getting more, but I think the vacuum cleaner wire I used to run from the panels to the Jetijs may be the issue of why I am only getting 1/4 amp instead of 3....
Mart
Mart
