Over the past year or so i have made about 4 different motors, all using very basic switching, reeds, transistors, mechanical. Ive started trying to adapt my latest one to switch with a bedini circuit and i have a problem with it. I cant get the thing to stop self oscillating, it wont run the motor, it just gets itself going. This is cool and all, but i want it to run the motor, not self oscillate. So it either self oscillates or does nothing. I turn the wheel when its doing nothing to try and get the motor to start, but nothing happens. I thought maybe i had the trigger wire reversed so i changed it, nothing again and would not self oscillate either. On the other side of the motor i have some very strong neos for a generator, i wonder if the field from these are strong enough to effect the motor from properly triggering. Also using magnetite cores. Any comments or suggestions would be appreciated.
I need help with a bedini
Jetijs,
Ok, at first I had a 100 ohm base resistor. I changed it like you said, down to a 10 ohm, it didnt self oscillate anymore as long as the pot was down on its lowest setting. But its still not triggering at all. I give the rotor a spin and i get nothing. The magnets on my rotor are south facing, i know bedini uses north facing, but i would think you could reverse the trigger wires to get it to workAnd i would think that because im getting a self oscillation that it must be hooked up right. Maybe ill have to reverse my rotor magnets
Any more thoughts.
Cody, show us some pictures.
I have made little neo rotors that would self oscillate on startup (connection to source). Like Jet said this is usually due to too high resistance on the trigger wire. You can put a small 12v globe on the trigger wire too, it can help servo the trigger currents if they are too high. Give us your specs and we may be able to figure out what is going on.
Oh and also, if its small, give it a REALLY good flick. One of mine wouldnt start unless you really gave it some oomph, but that was most likely due to the tiny magnets I used and their spacing."Once you've come to the conclusion that what what you know already is all you need to know, then you have a degree in disinterest." - John Dobson
When the Coils are singing, means your Circuit works.
Seems the problem is at the Power, what it can give to the Magnets, to turn it. Seems to weak , maybe you turn the coil?
Or try at backside with a ironsheet, how strong your magnet field is.
And the Frequency start low, mine usual works around 170-280, that it start.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Any more thoughts.
easier than turning the magnets over.
Nikola Tesla
ren,
this motor is a bit of a frankenstien, its mainly an adams motor setup. I got 2 power coils on one side of the motor, series connected 1200 turns 18ga 3.4 ohm power wire. 600 turn 18ga 1.7 ohm series connected trigger wire. Basically i have 2 trifillar coils and series connected 2 wires of each for the power coil and series connected the remaining wire of each for the trigger. On the rotor for it i am using very weak magnets, you might be right here, i might have to give it a really good push.
Joit,
So far the circuit only works when its "singing"(oscillating). Thats the problem, it doesnt trigger at all by the magnets passing it, i know its not turning on, i have an amp meter hooked up to the draw side so i can see when its firing.
sephiroth,
I have been playing motors and coils long enough to know how to determine which side the positive and negative need to going to, but to double check, did as you suggested and it does repel. My concern about the south facing magnet was about how the trigger would respond because im not very familiar with using bedini circuits. My problem is that the trigger isnt being tripped by the magnets going by the coil, it is either doing nothing, or its self oscillating, regardless of the rotor being spun or not.
hmmm... well as long as the circuit is wired correctly, the only thing I could think of that would force it into oscilation at low trigger resistance would be either the pot is fried (more likely because you say it doesn't resonate when it is turned all the way down) or the 1N4001 is fried (less likely... they are quite robust)can you test your pot?
Nikola Tesla
Hi Guys,
Sorry for putting this in this thread.
Seph,
Here is a picture of my setup using a timing led to see what position the magnet is in when the coil fires. Thought you could use it to prove your point. I have outlined the magnet and it direction of travel.
Cheers,
Steve.
P.S. Cody: Ditch the neo's for a start. Also, all of my motors have used south facing magnets because my coils are wound the other way. I have not noticed any difference in performance. It would help us a lot if we had a picture of your setup.
Cheers.Last edited by dambit; 03-31-2010, 01:10 PM.
Seph,
Here is a picture of my setup using a timing led to see what position the magnet is in when the coil fires. Thought you could use it to proove your point. I have outlined the magnet and it direction of travel.
Cheers,
Steve."Theory guides. Experiment decides."
Nikola Tesla
No no, its not oscillating at low resistance, but its still not triggering from the magnets. It self oscillates with high resistance from the pot. I just tested the pot and the diode and they are both good. The magnets on my rotor just dont get it to trigger, i wonder if its because they are so weak. And im still wondering if the other rotor on the other side (generator rotor)of the motor is screwing it up because it has very strong magnets and is in somewhat close proximity to my so maybe the field of those strong magnets is screwing up the field of my weak magnets?
Could be, that the other Field is to strong, imho.
You could place something like a Alloysheet between them.
It pretty eats the Magenticfield and slows the Rotor down, but it should isolate it, or maybe Iron, or a pice of the Metall from a Harddrive disk.
Or maybe move a stronger Magnet over your Coils, if they will do anything.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Originally posted by cody View PostNo no, its not oscillating at low resistance, but its still not triggering from the magnets. It self oscillates with high resistance from the pot. I just tested the pot and the diode and they are both good. The magnets on my rotor just dont get it to trigger, i wonder if its because they are so weak. And im still wondering if the other rotor on the other side (generator rotor)of the motor is screwing it up because it has very strong magnets and is in somewhat close proximity to my so maybe the field of those strong magnets is screwing up the field of my weak magnets?"Theory guides. Experiment decides."
Nikola Tesla
