@Xenomorph.What you are doing is very interesting.The fact that you are seeing minimal/no lenz effect and generating quite decent voltages as you say for free has got to be a step in the right direction.
I was wondering,if you can do this with one coil,can you add more coils and do the same?If so and the lenz is still minimal,you could just keep adding them.
I wonder how a small supercap charges on your setup?
yes you can add hundreds of coils if you want, the Lenz effect only hits when the circuit is closed which is totally avoided here. The limitation with our single magnet setup is just the space around the magnet.
I tried it with 3 coils that i squeezed close to the magnet
On a wheel-based multi-magnet Bedini you could add dozens of coils and use this charging method.
Or with the satellite approach of yours, since also the satellites wont stall.
I will test it with supercaps and with a positive earth ground in addition.
Also i will make a new main coil applying my new theories about coil improvement and try and different coil energizing circuit.
