Simple circuit diagram error
@Jeanna
Sounds like what you built is working OK. After reading your last post I was looking at my simple circuit diagram and found an error. I have posted that darn thing in 3 videos already.
. I had to go back into each video and put in an annotation explaining that the trigger coil start (B1) goes to the transistor emitter and not to the diode like I showed in the diagram. Sometimes people make mistakes in these diagrams and I am one of them. It happens.
If you don't think that you have the circuit right it might not be your fault but I have built both circuits that you have tried and they both work. I have not built the Daftman's circuit but that looks like a good one also. The "heavy duty" (zinc/acid) 9 volt batteries don't charge up well but you can use the alkalines I found out. The preferred one is a sealed lead acid for these charging circuits.
You are right about the circuit running without the rotor turning. It goes into self-oscillation when the base resistance is high enough. They still charge just fine that way. The "Solid State Bedini" thread here is a very long one that you might want to browse through. There are many Bedini experts at this forum who can answer any of your questions if they have the time.
I'm glad that you are having sucess with this.
Lidmotor
@Jeanna
Lidmotor
