@ synchro.Great post.I allways like to read yours as your ideas and insights are fascinating.
@Lidmotor.I had a little play with your motor today and it is quite a gem.I had it running on 0.8 v which i think is the lowest i have run a motor on and it may have gone lower.I have measured the rpm's with my tacho and on a 1.5v battery,the cylinder rotor was doing 3600 rpm's.I also tried some sphere's,neo and magnetite and they span nice and i got the snake egg going too but had to spin that up on the Bedini first as as you know its getting the magnet upright which takes juice but once its up its fine.
My motors LED flashes too and is what i think is happening is that the jouethief is doing its thing and oscillating away but these oscillations are not strong enough to spin the magnet but fine to light the led and the magnet triggers the transistor,lets say on the north pole and this is what pushes the magnet and then the south pole comes around induces a voltage in the coil which shows itself as a brightening of the led.The thing which has got me scratching my head and puts a bit of a dent in my theory is the amp draw is almost the same as when the joulethief is just running with or without the magnet so enter synchro's theory stage right
Could that one power pulse per revolution be enough to spin the rotor amongst the chaos of the pulses from the oscilator?or are the oscilations involved?.Can you see these power pulses on your scope amongst the oscilations?
Your motor is raising some interesting questions Lidmotor.Nice Work.regards jonny.
