  • Originally posted by Jbignes5 View Post
    Hey guys since I have been working on a new project I came across a few good ideas that might help you in your project.
    This idea comes from putting two magnets together poles facing each other. This effect called splatter extends out the space in between two magnets when the same poles are squished together and held there. A 360 degree lines of force squirts out from the seam of two magnets pressed together that is highly compressed and looks like a pancake:
    .........................s
    .....................(mag1)
    ........------------------------- <-n
    .....................(mag2)
    Looking down from above^
    I know this diverges from your current setup but it might make the the satalites work better from farther and increase the speed and power of the satalites. You could stack them on the same axle one on each end and get a better ration of cogging from the main neo.
    ..............S(mag(N)mag)S
    ........................I
    ..............N(mag(S)mag)N
    This is not oriented right but if you make it so the north field is 90 degrees from the south field then it should work. Also if you retard the degrees off a bit the field line would attract from top left to the south lower south pancake. Looking like a propellar. this could give you a mecahnical advantage seeing that a field comming from the main neo would be rounded and blunt and the field on the satalite would be a sharper propellar shaped giving more ability to push the stalite with more force but at a slightly slower speed.
    It would be interesting to see what could be done with that or if I am correct about this idea....
    @Jibnes5, this configuration reminds me of the Bedini Scalar Beamer. Makes me wonder if a properly configured beamer would exhibit SEC type effects at high rotational speeds??? I'll have to think about this one for awhile
    Alt-Science
    RD
      Have you tried putting 4 coils around the shere and generating in parallel all 4 coils. That way your big mass will have coils generating from oposite sides and not pushing your 2 incher all over. Even more coils would help to keep it in place without having to use any other method to keep it in the middle. You could try pairs or a set of 3 coils to balance it as well when generating serious power. Taking the coils and moving them out some might lower the generation interferance or counter force associated with generating heavier loads. Maybe setting the coils to a 45 degree angle facing down might give you even more control of the super huge magnet you got. In effect, holding it down to the surface and centering it from the even pushback against the lines of force when the coil generates. this also would mean that you would have to make the generating coils very accurate and twin like or triplets if you will.
      Using one generating coil on one side is a very dangerous thing with that big of a neo. Adding more generating coils from apposing sides should stablize that beast and allow you to see haw far you can generate with it. I would stay with pairs and add them till it becomes rock solid. You should be able to add coils in a full circle stacked right next to each other at a distance of about 1 foot or maybe farther and still generate like a banshee without killing it's orbits to much. The more points you add to the generating circuit, points=generating pairs, the more you can pull from it and have the Sphere stay stable.
      It's time to add more coils. My original Idea was to have a ring of coils for the 45 degree marks from the neo. Looking from the side of you unit:
      Top ring..............(\)............(/)
      middle ring..........(-)...(neo)...(-)
      Lower ring............(/)...........(\)
      ................................_____
      Side view...................(drive)
      ...............................(coil...)
      This way the rings act like a virtual ball bearing set around your huge neo. you could make it a three coil generation circuit I believe this way as pictured above each side being a set of 3 coils in series or paralell. With 6 coils per ring at even spaces in a circle, above and below being tighter or closer together. if it still interferes or has a cogging issue then just adjust the generation coils till you find the sweet spot. One suggestion to make here would be to make each coil set from one side mounted on wooden arms to make easier the adjusting of the distance of your coils from the neo. 1-4 feet should be enough to see if there is a break point of the generating coils feedback to the main neo. Meaning when the coils generate, since the reach of that monster is so huge that you could effectively generate without changing the speed of your main neo. I would suggest that maybe it is time to try the satalites out with that monster to see if you could have other neos around the big one that could generate and have less effect on the main neo.
      That 2 inch neo should have quite the pole sweep. Cogging it with a 1 inch should prove that it is possible to chain these mags together and not have the satalite effect the main neo with a good amount of generation possible. Having a 1 inch around the 2 inch might be extreemly dangerous but start at 5 feet range and see if the 1 inch will spin with good force. When you try this it would be a good idea to enclose the 2 incher in a tube or open ended box for safety.
      When using satalites the generation is from the satalites not from the main neo so the main neo will stray some. The suggestions to keep it there could be applied to the main neo for the satalite test.
      @Jbignes5 some good ideas here. I had planned to continue my wotk with the large sphere when my hobby piggy bank allows. I have noticed the highest voltage gains from the spinning sphere are collected in a large vertical coil that crosses the top of the spining magnet (right through the 'e' in neo on your diagram). This is also the area of the magnet capable of spinning non magnetic metal materials shown in other videos. When you hold a magnet in your hand 5 or 6 feet away from the spinning magnet you realize there is more energy available then with using conventional coils.
      So everyone play safe and I will rejoin the fun hopefully soon.
      RD
      • Homopolar one magnet Bedini Variation
        Greetings and felicitations JonnyD and RetroDave, Lid and everyone.
        I have had an idea but my apparatus is still packed away so I can't test it. I was hoping to convince one of you hardcore sphereists to give it a whirl (pun intended)
        I hope I can explain it well enough without a drawing but if I am too obtuse, let me know and I will sketch up something.
        In the most basic form, set up a one magnet sphere Bedini to run on top of a non magnetic plate of aluminum copper, carbon or stainless steel or some other non magnetic conductor. Attach the output side of your bifilar coil to the plate and run the other side of the coil to the top of the sphere where it lightly makes contact so the back emf spike actually pulses through the magnet and produces a homopolar motor drive impulse.
        If my theory has any legs, the back emf pulse will directly drive the rotation of the magnet in addition to the primary pulse. After you find the sweet spot and fine tune it, the hypothesis is that you will need much less input power to drive the magnet due to the direct conversion of the feedback pulse into rotational energy. Using a sufficiently large neo sphere to preserve momentum, you may be able to place some pickup coils around it attached to jule thief circuits and loop their output back to the drive coil or supply capacitor to create a self runner circuit.
        I hope somebody tries this one out just for the novelty.
        Keep on spinnin...
        El Tigre
        When you pick up a cat by the tail you learn things you cannot learn any other way...
        • idea.. about motor..
          Keep on spinnin...
          El Tigre
          The trouble with this idea would be getting the magnet to stay still under contact of the wire. This may work with something like my VCR bearing setup that I have...
          I think I understand what you are saying I have created a homopolar setup with a sphere it spun like a banchie. So what I am seeing you say we would get two bangs for the buck, one from the bedini kick and also one from the homopolar motor pushing the magnet. This should in theory have higher rpm than just spinning the magnet alone.
          I see what you are getting at. I may try it out and see if I can get the homopolar motor working with my vcr bearing setup....
          Thanks for sharing!
          See my experiments here...
          • Homopolar Bedini
            You can stabilize spheres quite a bit by slipping a 2mm steel washer under the plate they are spinning on, but yes, this may be the biggest problem. You may need some type of fine wire mesh (maybe a slot car brush or other type of cats wisker contact) to lightly brush the very top axis of the spinning sphere so as not to nudge it out of position.
            Exactly so! or if not a higher rpm, perhaps reduced current draw from the primary for the same rpm.
            I'm sure that would work to demo the concept and may be easier to set up the apparatus than a free spinning sphere. There will be lots of tweaking with this one for sure.
            Thanks for sharing!
            Thanks for your interest.
            • Sewing machine bobbin Bedini
              @ Jonny & All
              I wound up a simple bifilar coil on a plastic sewing machine bobbin and it worked for a Bedini style pulse motor coil. Here is a video of it running on a little solar energy and spinning up a neo ring magnet rotor on a mirror.
              YouTube - Bobin Bedini.ASF
              Lidmotor
              • @Lidmotor.Great motor. That bobin coil is the smallest Bedini coil i have seen and it seems to work great.
                To spin the cylinder rotor which is a fair weight at 500uA is quite amazing and on incident light as well and as the power consumption is so low,the way you can power this motor are many and as you can run a load ie maggie,i wonder if maggie could charge a cap up and supplement the motor or run another bobin bedini and with an avramenko plug in a sec field ,this would spin for sure.Really nice Lid.Regards jonny.
                @El-tigre.Great idea's you are coming out with and i think this may work with Marts setup.Keep the great ideas coming.Jonny.
                • Wireless Bobin Bedini ?
                  Thanks Jonny for that idea about running this off an AV plug in a SEC field. That should work. It should also work at the end of one wire off a SEC. That would be cool----have a SEC running and then run a long thin 30ga. wire 20 ft. away. Have this little pulse motor running at the end of the one wire ----and 'Maggie' lit up.
                  Lidmotor
                  • Feedback loop
                    Lidmotor
                    Excellent demonstration Lid, very economical to run. Have you seen the adaptation developed by Sepiroth on the ssg thread. He came up with a choke coil added to the drive circuit and it cuts power consumption by 50% in regular bedini motors. I have tried it and almost any very small fine wire coil works as long as the resistance is not too high or too low. You will need to experiment to find the right match with your new rig. I have scrounged working choke coils off of scrap circuit boards microrelays etc.
                    Also, ss I mentioned above, why not try to feedback the power you get from your maggie or SEC coil directly back to the magnet in a homopolar configuration... It's very simple to set up a trial.
                    http://www.evilmadscientist.com/arti...HomopolarMotor
                    You may have to jack around with the polarity (maybe need to add a bridge to rectify the coil output) and the physical location of the wires etc. but I think it's worth a try with your ultra low power consumption - I think you are nearly there
                    good luck
                    • Bobin Bedini running wirelessly off SEC 15
                      @ Jonny
                      I just had to try this and it worked. What was a BIG surprise was that an AV plug picked up energy all over the little motor circuit while it was running. I used the SEC tower arrangement to first transmit the power across space and then took the energy down one thin 30ga wire 9ft. away to run the motor. It was a very interesting experiment. Thanks for suggesting it. Here is the video of it:
                      YouTube - Bobin Bedini--Run wirelessly by SEC 15.ASF
                      @el-tigre
                      I am familiar with the homopolar motor but I don't think that it will work here because of the polarity of the magnet. The homopolar motors that I have built had the poles at the ends. On these one magnet no bearing motors the poles are on the sides. Maybe we can figure out a way to still make it work.
                      Lidmotor
                        @ Jonny
                        @el-tigre
                        Lidmotor
                        Hey Lid,
                        Theremart tells us he got a homopolar sphere to run well so I think the idea has some legs. Maybe the connection wires need to be on the top and bottom of your neo, 90` away from the diametrically opposed poles. A conductor plate underneath is the easy part (How about a bismuth plate to give a little lift to your neo) but the top wire will be more of a challenge.
                        • @Lidmotor.Great vid.I think you would have tried this anyway
                          The vid shows some interesting things.The first is the transmision of energy down one wire over distance.This reminds me of the good points of AC and bad points of DC with the latter not really transportable over long distances.This bodes well for SEC energy one wire systems.
                          Also the motor seems unaffected by the energy all over the Bedini coil but it maybe worth checking with your scope,just in case you are getting a boost from the sec energy when the transistor fire's.
                          A third winding on the coil maybe good for collecting the sec energy on the bedini coil and you may benefit from induction at the same time.
                          Your motor and Dadhav's window motor are the only seriously sub 1mA motors i have seen and i can see you having lots of fun with this one. Many thanks.Jonny.
                          • Bobin Bedini &amp; the famous glass of water
                            @ Jonny & All
                            I had to try this thing with the glass of water and the SEC. It ran on the energy coming out of the water. Amazing!!!
                            YouTube - Bobin Bedini & A glass of water.ASF
                            Lidmotor
                            • I wonder if....
                              I wonder if the energy could be sent through the wall to another room even though there is sixty/fifty hertz alternating at a lower frequency and use the household wiring
                              • Jeff Cook Effect
                                I think the Jeff Cook effect has some promise. It is stated that the wire does not even have to be continuous, you can have breaks and stuff. So, if you wound a bifilar with ferrous wire and got it to oscillate, do you think the JC effect would work with or against us?
