  • 6 volts DC IN -110 VOLTS AC OUT GENERATOR
    The below link will show what I have constructed. An explanation is there also on the U tube. Looking to obtain 300 volts AC then I will figure input and outpot electrical power compares.
    Here is the link:
    YouTube - 6 VOLTS DC IN 90/110 VOLTS AC OUT GENERATOR 6&7
    Tom
    • Feedback loop
      Well basically all I tried to do was just plug the energy straight back into the motor and if you think about it ---that will never work. It sounds like a great idea but it just doesn't work.
      Lidmotor
      Yes, I understand, that is why all the suggestions to feedback power into a secondary drive apparatus like a cap feeding another coil with a reed switch or direct to a homopolar arrangement.
      When you pick up a cat by the tail you learn things you cannot learn any other way...
      • Lafont generator
        YouTube - LaFonteGroup's Channel
        Butch Lafonte has discovered an approach to effectivly cutting off magnetic flux with a slotted stator. I wrote and advised him at his overunity thread that a single diametrically poarized Bedini spinner would act as a frictionless rotor. I believe this combination has real potential for achieving overunity. Click on the hyperlink up top to see his invention.
        • Hi. Here is a vid of Alfacentauro's latest motor.He has a sphere magnet spinning at 60000 rpm UNDER WATER.This opens up the possibilty of using this type of motor in a whole range of devices from pumps and turbines to wave generation and many more.Jonny.
          YouTube - Bedini Round Magnet under water high RPM "whiskini"
          • That is amazing. If you show up with that one on a cocktail party, you have all the female attention
            • LOLOLOL @ Whiskini ( brilliant !! )
              • New Jet Ski Motor??
                That was great. Maybe a new jet ski motor? Be sure to wear a face mask and a snorkel. That was amazing.
                Lidmotor
                • Things that make you go hmmm.
                  I wonder if you could get a submerged sphere spinning in a flask of mercury? Stick a conductor into the top and bottom and you may have a very interesting generator
                  • Mercury spinner.
                    The mercury contacts might work better if positioned like the Faraday Disk: One on the top and the other off to one side, to generate current from the voltage differential, rather then top to bottom.
                    • slightly off topic
                      does it matter if the Bedini SSG wheel spins clockwise or counter clockwise?
                      I have an Imotep converted fan charging batteries and it will run either direction.
                      Which is correct or doesn't it matter?
                      Don
                      Don
                      • RE: direction.
                        Don
                        Interesting question. I have found that the rpms are different on which way you turn the fan. I have always went for the fastest rpm for the sharper pulse to the battery.
                        If you you have Energy from the Vacuum II in there Bedini demonstrates the 10 coiler. It seems that it ran better one way verses the other, as he stops it again and starts it the other way.
                        If you think about it the fans blade would move air in different way depending on direction of rotation so one way may have more drag than another.
                        I guess you have to ask your self what is your goal? Is is more air flow, is it the highest charge rate on the battery? Or is it the most efficient means of charging possible.
                        The goal you pick will determine which way to spin the fan blade, and how much resistance you add.
                        See my experiments here...
                        • Originally posted by theremart View Post
                          Thank you.
                          The amp draw is greater when running the "wrong way" based on how the fan is supposed to move the air. This makes sense because the drag is greater when trying to push the air back into the housing of the fan. I'm sticking with the correct way, higher rpm and lower amp draw from the source battery.
                          Don
                          • Hi .Here is a way of supplying a spinning rotor with a DC current.
                            I set up to independent circuits.The one magnet no bearing bedini motor and slayers sec.I put and led and avramenko plug inside the central hole of the diametric cylinder rotor with a small piece of a drinking straw as side insulation and the avramenko plug,sits on the steel ball bearing pivot.I used a small piece of wire on the negative leg as a virtual ground.
                            The magnet was spinning on a conductive surface(tin foil) and the slayer secs output was connected to the tin foil but it will also light wirelessly.This was only a prototype but you will get the idea.Jonny
                            YouTube - avramenko rotor
                            • Magnet man.
                              YouTube - scooterscottii's HVHF gravity experiment Scooterscottii has demo'd a Townsand Brown effect, gravity loss in a mag lev spinner. This is a Zaev indicator and should be coupled with cooling and electric power generation. Magnetman12003 is measuring a C.O.P. of nearly 4 spinning his cylinder inside the air core of an output coil. The pulse is probably causing a mag demag cycle. I have a large order of diametric cylinder magnets on the way, and plan to try a freely rotating spinner on a movable tray, and a large custom built pickup coil to house it. I would like to try and spin a Nanoperm core, with an axially magnatized cylinder in the toroid air core like Naudin's 2 S Gen, both inside the air cor of a pickup coil. This should mag demag the high perm toroid core like the copper wraps do in Naudin's experiment, at a higher frequency, and perhaps output even more power than the magnet alone. Two kinds of scaled up Lidmotor's Maggies. Finally back to the shop after 2 years in South America. Located my video camera too. Look foward to some new video's soon!
                              • Originally posted by synchro View Post
                                Hi synchro.This is great news.You must have been frustrated at not being able to try out all your great idea's but you shared them anyway It sounds like your going to make up for lost time in the shop but i must admit you have contributed to the experiments here greatly and i can't wait to see what you come up with..Jonny
                                @all.I have been focusing on SEC exciter variant circuits recently and i combined the two technologies,motor and exciter and forgot to post this vid here which i will now rectify.I am getting some very interesting effects with this "One magnet Bedini exciter" one being the motor self starts and purple plasma from the exciter.The self starting is not shown in the vid as it is a recent discovery but i will show this in some future vids.Jonny
                                YouTube - One magnet Bedini exciter
                                This vid is without the rotor spinning but shows the plasma and a couple of circuit mods.
                                YouTube - Bedini SEC Plasma Propulsion
