  • In the first video I linked, he also engages the High-Current coil while the High-Voltage coils were still accelerating the rotor; it continued to accelerate while lighting an incandescent bulb. This did not happen below the threshold RPM and with the High-Voltage coils disengaged.
    Applied Magnets : Magnet Wire Spools - discount wholesale prices. had 11lb spools reasonably priced :3
    • Originally posted by Xenomorph View Post
      BTW: Anyone knows the cheapest magnet wire supplier?
      Junkyard, there is still a lot of Wire around, some Motors have any Kind of Wire on it,
      or some bigger Transformers still got few meters usefull Wires on it, 0,2-0,8mm, especially Microwave Transformers.
      I saw at Ebay some Cheap Roles too for last Chance.
      • Current flow.
        Just because current drops off doesn't mean the coil isn't highly charged. The high voltage coil maximises magnetic force per watt as an electro-magnet, conversly it maximises watt for amount of magnetic force as a pickup coil. As the voltage increases in the coil, the resistence drops toward the vanishing point, reducing Lenz drag. Now the coil begins to act as a capacitor, and stores power as flux rather then generating a current. Lidmotor's input drops when he disconects his third winding, and his back EMF
        drops as well. He should find that his input drops when he connects his third winding while his magnet R.P.M.s increase past the High voltage Lenz decay point, like Thane Hein's motor generator. When resistence drops toward zero and the coil turns into a flux capacitor, his stronger neo magnet rotor at high end R.P.M.s, should behave just the opposite.
        • Originally posted by Joit View Post
          It dosen't help to loose the map to the mine field.
          • Originally posted by synchro View Post
            Huh? Its just picking up some Mines.
            • Low Speed Ball Magnet Bedini
              I put the 1" Hematite ball magnet (still don't have my neo) inside a plastic tube and put the tube inside the air core coil and it worked. I was able to get the thing to run slowly and still put out a good charge at a low amp draw. I put a little 3in1 oil in the tube to lubricate the ball.
              Here is the video---
              YouTube - Low Speed Ball Magnet Bedini
              Lidmotor
              • How did you get the magnet to initially spin? was it spinning when you shut up the tube, or was it started externally? Hmm. Very contained. Can you pick it up and shake it a little to simulate walking or running, and will it run?
                Nice.
                • Microwave Proportion Hi Voltage Output Coil.
                  There is no confusion on the number of wraps for a maximum efficency Hi Voltage Electo Magnet Coil. There are tables for coil dimension wire gauge etc. Type "Hi Voltage Electro Magnet Coil" in the Google search box and a web site comes up that will sell you plans.[url=http://www.fuellessengineplans.com] Click on "High Voltage Magnet", be carefull, these coils can deliver a fatal shock! Bedini and Bearden believe that when the Hi Voltage Coil reaches saturation, the power in the wraps weds. After that the output is comming from the G-field, or background power of Space Vacuum. Imagine us at the bottem of a sea of power, the super charged coil as a leak in our submarine hull. The background power of space is in the microwave spectrum. The wave length of 12.2 meters has a two to one relationship to the amplitude. JLN Labs has a microwave plasma experiment with a rectenna base of 6mm and a height of 3mm. A high voltage coil built to these dimensions should broadcast a microwave conformal output at resonant frquency, and gain oscillation feedback from the microwave fabric of space time, as the galaxy speeds toward the great attractor in the constellation Hydra.
                  • @synchro : Do you honestly think that a simple google search will give you the exact specs for such a specialized job like a pick-up coil for a one magnet bedini motor ?
                    All that comes up is endless pages of Tesla coil specs.
                    From Heins videos you can vaguely guess the spool dimensions, he even mentions the wire gauges and the resistances.
                    But his rotor creates a much higher power than the one magnet thing, so the wire gauges cant be so easily adapted. He uses much higher source voltage.
                    Thats what i mean with pain-staking experimentation for optimization for the one magnet power level.
                    • Starting an enclosed ball magnet
                      Nice.
                      To start this thing you just shake it a little or tap the power on and off. The real problem is that the circuit wants to self oscillate. Thats not a bad thing but if you want the ball running, walking, or doing a jig---you first have to get the circuit to stop singing on its own by turning all the dials down.
                      Lidmotor
                      • If you include the batteries in the oscillations, wont you get the aspects desired from "ringing the battery"? For total energy gain, wouldn't you want that? Other then getting your circuit noisy, what affect does that have on discharge battery compared to when its not oscillating? Hmm too many questions I should try it myself...
                        • Quick neo magnet test
                          I finally aquired the right steel ball to put under the neo magnet cylinder (8mm and it works fine).
                          It can produce about a steady 10 Volt when picked up with a 2000 turn air core coil.
                          The voltage was measured right behind the bridge rectifier without capacitors, but a capacitor would reach quite a high voltage i assume.
                          Video: YouTube - Neo magnet generator
                          • @Xenomorphlabs. Try [url=http://www.fuellessengineplans.com] Click on "Hi Voltage Magnet". They advertise plans for 16.95. The "Hi Voltage Electro Magnet" google search category is the correct one. Sorry for misdirecting you to all those Tesla resonating generators. You will see a fat tuna can Thane Heins style coil on the Electro Magnet page. The coil design is the same for output. The strength of an electro magnet is the product of current times turns, conversly the output in current is magnet strength times turns. More wraps more power! No real mystery there. The coil is three inches in diameter and two inches high. You can probably save the money just by wraping thin wire to those proportions.
                            • Jonny:
                              I just ordered five 1" O.D. x 1" long diametrically magnetized tube magnets. I can't wait to see how these run on my frying pan lid device. This was a great discovery you made. Thanks for sharing it. For those here that might not have seen it, this is my video of my snake egg replication using the magnets sent to me from Jonnydavro. (Thanks Jonny)
                              YouTube - No Bearing Bedini IV
                              Bill
                              • I would think...
                                Maybe the snake egg mags are now defunct. With the spheres we are seeing speeds that could actually open something new up. I mean 150k revs is the most astounding speed that might make it possible to see new effects. Maybe we should concentrate on the spheres and drop all the weight of the tube shaped are carrying. Are the spheres self starting? or easier to start?
                                Has anyone used a larger sphere with a more powerful field on it? If we could get neo strength of field I bet the spheres would manefest a new effect at those speeds. Has anyone generated voltage from an air coil off of a 150k speed. I think this is the area we should be interested in experimenting on.
                                I would also assume spheres to be easier to link together but we need to start going down that direction to find out.
