Hello everybody !
it's my first web post on free energy, so, i want first to thanks for this forum and all the free energy researchers & peace workers & all the spirits wich work for us.
i want to speak about my understanding of the stange effects occuring in the components of Bedini's charger :
-capacitor and tunneling/electret effects, cold boiling and pre glow discharge with ormus generation in battery, tunneling effect in transistors, zeta potential and radiant energy collection, and little more..
Perhaps i make big mistakes or misunderstands, and i am OPEN to all constructives critics, each others we catch understanding by various ways and i think it's important to release a part of these investigations (and sorry for my poor english : i am learning everytime !)
I note there is a lot of questions about Capacitors : HV / low farads vs LOW voltage / high farads... radiant energy conversion, anormalous production of energy after totally discharged... and understand what is the transformation of normal capacitor TO "conditionned capacitor" (regarding to Free energy generation book)...
each subject has his topic :
ABOUT THE ELECTRET EFFECT :
In fact, i have seen nobody speak about the ELECTRET EFFECT in the Bedini pulse cap' discharge,
According to my understanding of the phenomenon, i will try to give you clear explanations of this effect : an electret is simple free energy device, it's a capacitor wich recovery itself its charge without charging it, normally you make it by passing pure DC high voltage through acrilyc plastic capacitor heated around 300°C (but others materials are possibles), voltage depends of the thickness/material of the dielectric, after turn off when it take cold, you wrap it in aluminium paper, wait 2 or 3 weeks (becareful when you removed the aluminium paper, this is high voltage!) and you have a capacitor wich take itself the ambiant energy, charge in 2 or 3 minutes and it can be discharged every 2 minutes or so, since a dozen of years ...There is a voltage amplification: if you treated it with 15KV you will have something like a 20KV discharge.
The ambiant energy is very high frequency oscilations ... so high there's not a lot of things for catch it freely like electrets : germanium diodes but with very little power, So for catch it we need supraconductors here........... SO guys, WHAT IS THE MYSTERY of electrets ?
That is simple, by application of electricity through the dielectric , We stressed the dielectric wich take a little amount of time to be polarised and conduct electricity like in a transistor, the energy pass by "tunneling effect" in the dielectric,
---Some scientists discovered that : cosmic particles pass more rapidly through matter than in the vacuum by "tunneling effect".
At a sufficient level of energy (voltage and current) this tunneling effect becomes permanent : the dielectric is printed by nanotubulures (very very thin tube) were electricity pass.
So, we make NANOTUBES in the dielectric, and if the dielectric is based on carbon, so you make carbon nanotubes (search on this), in other mediums, you can make others nanotubes... in fact these nanotubes are supraconductors, and have an other very great particularity : they conduct the electron flow in just ONE way !
In an electret capacitor thousands of nanotubes are polarised in the same way (if DC treatment) and they catch the ambiant high frequency oscilations and charge the plates of the capacitor, so it's a simple way low cost to make supraconductor here !
Another consideration : when you treat your electret one side with positive, this side becomes negative, and inversement.
At a lower stage of energy, dielectric is not printed by physic/ solid nanotubulures, but it occurs as low energy plasma "tubes", wich are removed after the electric stress.
--- why is there a voltage amplification in a discharge ?
Nanotubes has been discovered since a time, and there is already any applications for new generation of televisions wich will use carbon nanotubes in place of the cathodic tube, simply by adding a coil around nanotubes and you have a electron cannon...
Generaly Electrets are heated under High voltage (15 / 30 KV) with 3mm acrylic plastic capacitor, but you can use others materials here.....and Thomas Brown added metallic powders [heavier the better] in the dielectric to increase wattage (but less voltage), (if the metalic powders are ferromagnetic its will help for something).
I see a nanotube like a nanometer supraconductive secondary of a tesla coil freely oscillating in the ambiant oscilations, mounted with a very fast high voltage diode connected to the plates of a polarised capacitor....
You can try to play with a magnet around an electret you will see the interaction like with a little coil...
---Some scientists disvored a "field effect"around the plates of capacitors.
Can you see that ? a supraconductive (HV) nano coil wich conduct electron in just one way....
So, you have a very special capacitor, and when it is discharged strange properties appear because thousands of nanocoils are in the dielectric :
1- the discharge cause EM/scalar stress through the capacitor, wich stress the nanotubes = generate high frequency oscillations in the output pulse,
2- the electric stress create back EMFs into the nanotubes = making high freqency oscillations,
3- discharge cause nanotubes can suddently collects ambiant energy, that's create a vacuum in the scalar field (like thousands of nano black holes)... wich attract strongly the scalar field, and generate resonance with the vacuum = generate high frequency oscillations...
So, Stop here if you think about that, it's can be a key of free energy, because at this moment, when we conduct the scalar field momentainly polarised by the nanotubes through the load- COP is infinte, So, you connect the load to the polarised vacuum wich generate very high frequency pulses like an infinity of polarised particles wich resonate with the discharge stress.
Another simple consideration : if you look the discharge of variants tesla coils you can see differents forms of arcs : white and thin with a classic solenoidal secondary or large purpule flames with flat spiral secondary... when the arc pass through a solid transparent glass or acrylic plastic we can see the forms of arcs,
http://205.243.100.155/photos/For_Sa...Discharge1.jpg here an arc in acrylic plastic
http://205.243.100.155/photos/For_Sa...Sq/Square1.jpg here we can see bigger tubes than nano because high energy tesla coil since long time..
There is various forms of arc, The Turn Of The Century Electrotherapy Museum (C) Jeff Behary 2007 -Thomas Burton Kinraide Archives - 22 x 28 Prints from the collection of Steve and Pamela here glass treated with kinraid coil
and we can see what if a coil have good vortex effect (spiral, kinraid coil) the tubes printed have more branch of trees. we can see that too in the of rodin's coil field
http://jnaudin.free.fr/html/magvtx.htm
The nanotubes (or low energy plasma "tubes") formed in a capacitor take the form of arcs in air... what form did you prefer trees or just a branch ?
PRE GLOW DISCHARGE and ORMUS GENERATION in BATTERY :
Bedini chargers create very high frequency voltage oscilations in the battery, wich cause pre glow discharge between the plates, pre glow discharge (see Korrea[s]'s research) is a short timing BEFORE the right discharge of current, since this very little amount of time a strange thing occur : a tiny amount of matter on the cathode is vaporised, and form very little crater on the cathode, matter pass through a another state : matter to gas, this is sublimation ("magnifiying" said tesla for his coil), the gas released form a tunneling/ vortex in the way of the anode, but STOP his way in the middle way between the battery's plates, because at this moment the medium (electrolyte here) create a resistance to be polarized, and the conduction stop here... it generates very short pulse (dozen of nanoseconde) into the battery's plates.
The matter vaporised/ transmuted in gas has released high state energy materials : ORMUS particles, ormus are supraconductive nanoparticles at room temperature, and when they are present in the battery, since the battery's discharge they attract the scalar field and conduct it to the load by low state nanotubulures in water/electrolyte between the plates (my opinion !)
--- I think this is why the capacitance increase in conditionned battery : billions of tinies craters increase the area of the cathodes.
--- Ormus particles have anti-gravity properties, this is an explanation of fluctuations of the battery's weight
When the electrolyte of battery is fully charged of solubilised gas/ormus particles, water start to boiling because gas bubbles are formed in; ormus have implosive properties, and when it form tiny bubbles, they implode and generate a blue/green light wich release energy.
This is sololuminescence, cold fusion... same things as joe cell & likes.
Ormus can pass through anything and in conditionned battery the gas is in the same time in and out of the battery.... Mr Bedini say something like that "in conditionned battery energy is more out than in".
There is various way to catch ormus, but Barry Carter say that is possible to catch it in magnetic collapsing fields... this is under our noze ! (french """expression""")
The ormus particles resonate at the MHz range, and WHAT DOES BEDINI with his "10 000KHz" resonances in the pulse? what do tesla with his "magnifiying coil", and the others ? discharge into high impedance to generate very high frequency by collapsing field / resonnance with the nanoparticles (ormus) medium,
righ no ? Gray tube, secondary of tesla coil, joe cell pulsed are always discharge into high impedance; just different form... scalar or EM/scalar field, no ?
Can you see that ? An ormus particle is described like a tetrahèdre of very high spin with an electron of very high spin around it... this is like a nano spinning top, a rotative little supramagnet, so they are attracted by themselves and form a merkabah1 : Two tetrahèdres overlapped in themselves, making cancellation of magnetism, no EM energy, but now a monopole magnet, scalar energy we can't measure with conventional EM technology, strike it at 90° like Flynn do with his monopole magnet (VTA) and they release EM energy, what happens every time in discharges wich polarise the monopole medium wich become a little time an infinity of resonant nanomagnets, wich resonates at "nanofrequency" (the MHz range)...
Pre glow discharge occurs with voltage but don't need current -or very little-, i think this effect is just a part of what bedini charger does, radiant discharge create
high pulsepower of free electrons of high state energy, is there others effects than pre glow discharge ?
--- Mr Bedini says "the right amount of current at the right time" (or like that), I want to understand more on that, anyone can help me ?
![Smile](http://www.energeticforum.com/core/images/smilies/smile.png)
![Not Worthy Smiley](http://www.energeticforum.com/core/images/smilies/notworthy.gif)
