Originally posted by MileHigh
There are people taking for granted all science back from ancient Elade is flawed.
(I don't)
I really appreciate having attention to a "seen all, been there" practical "man of the trade". I hope we be worthy and keep it?
As hobby scientists and layman often don't understand, the engineers really truly miss the "in-drawer science" in the filed, as much as common people (The old lady on fixed income icluded
StevanC: I think that you are looking at how capacitors work in Bedini setups where you can clearly see the voltage increasing when connected in the place of the charging battery and mistakenly applying it to the convertor setup. This does not really translate and a cap will not be much use in determining the power output of the convertor. They are simpy two different beasts.
(snip)...
(snip)...
I look how a Capacitor interStage (CiS) acts to a power source:
It is capable to really "suck" heavy amperage and deplete really high voltages.
It seem, to my uneducated mind at least, like low impedance input with a low impedance output.
I understand that our common PSU would not like this:
If I would introduce a 75 mF CiS to a walwart PSU (12V/12W) i would probably kill the diodes of it's FWBR if I dumped down to zero (directly to incandescent light bulb of 12W)
but (always
If I put that 75000 uF (=75 mF) CiS to dump at , say 14V, and dump it to a chraging battery (12.1 ... 13.8V) it would dump only every now and then, the FWBR would even be cold.
I had matched the load this way...
If I had to dump to a 12W light bulb, but had to use a CiS to quantize the energy, I guess i had to do it this way:
[PSU] -> [75mF CiS] -> [75mF capacitor ("condenser") ] -> [TPC]-> (Lightbulb)
what is a #*@! [TPC] ?
It is a simple device called Termination point controller. There are many types, they just switch off the load as a preset condition has occured.
I had made a really simple TPC that triggers off the load if 11V...17V level is depleted on the powering side.
This way, the bulb would pulse, but the PSU would never see a Capacitor loading it lower than the TPC set voltage - be it 12V or what ever looks fit.
@ MileHigh,
how about that?
Good luck all!
Kind thanks, and the same to You too.
Stevan C.
P.S.
To avoid being seen as "just thinks" I share some of my work
note:
The TPC v0.1 is a bit Lying
