Questions for clear understanding.
To Matt,
Maybe I am bothering you, but I really want to make clear my questions in my mind and go steps further. Please let me have your another opinion.
[In a permanent magnets field you have 2 bloch walls (or zero points) in the center of either direction in the magnet. 1 bloch wall is parallel to the pole of the magnet, the other is perpendicular.
The parallel zero point (Nzero) has a steady flow of energy coming into the magnet.
The energy coming in is NON Divergent.
It does not have mass as we would see it, but it is energy. This flow is compressed at the center of the magnet and is converted to energy that has mass. Then it released from the perpendicular zero point (Pzero) as energy. This energy is more like what we see in circuits. Or what most call the electron.]
-->You said there are two bloch wall in a permanet mangnet(or a electric mangnet). The parallel(Nzero) is between N-pole and S-pole, the perpendicular(Pzero) is on the N-pole and on the S-pole. Am I right?
[The machine stops the conversion at a point in which the energy flowing in from the Nzero has compressed to mass but has not made the conversion. It is now energy that emit a photon flow like the electron but is opposite in nature (IE cold current, or Negative energy, ect).]
--->'AT A POINT' what do you mean by this 'at a point'? frequency(rpm)?
At(or after) that point the machine stops the conversion massless energy into
mass energy(magnetic field). You mean THIS?
[So the Iron in coils gets pulled in by the permanent magnets, as one would expect.
Once aligned, the Nzero flow fills the iron in the core.
The iron induces a charge of this energy on the coil.
The polarity of the coil at that point is opposite of the magnetic field that is present, in the machine.
The coils induces a photon back into the iron.
The cores eject themselves from the permanent magnets field (IE North facing North).]
--> I think this is the main point for speeds up under load, but hard to understand. Could you explain more about this. I think this kind of motion also happens in a normal generator, but we can't see speeds up under load in a normal generator. I can't uderstand its polarity changes after TDC(and before field collapsing)-in lines with stator(mangent) and Rotor(coil).
[The field is collapsed and the negative energy flows out the coil where we can catch it.]
-->I think the negative energy flow is not related ANTI-Lenz Effect.
Lenz effect no longer is valid. (IE 2 north magnets facing each other).
-->ANTI Lenz Effect is only for mechanicals(ROTATING flux gate generator)
[If you are measuring significant amperage (.1+) from a Kromrey converter your machine is not spinning fast enough. Gear it up.]
-->For less current and high potential we generally approach the more turns winding, but there is impedance problem in many turns winding.
JANG YOUNDEUK
To Matt,
JANG YOUNDEUK
