xpskid - i could not get the coils to work when they were wound in the same direction so i peeled one apart and rewound it so the coils are wound in opposite directions and then connected in series. They each consist of 4 strands of tight twist 18ga. about 300 feet long and one 22 ga. trigger wire as the monopole junkies will recognize all twisted together and soldered together at the ends so they are in parallel. I do have an inductance meter so i can measure them for you. The coils are about 3.5" in outside diameter and are wrapped arround a 1" steel bolt inside a pcv pipe with acrylic 1/4" side pieces. The bolt is anealed in an oven at 2000deg. F for a few hours to grow some oxide on the outside - not sure that is important but it does keep them in place I got the same results many in here got until my wave form looked like the one on Bedini's site for the stationary coil unit Ron Cole put together. I will post the scope trace of Ron's and mine when i get home. You may have all noticed but the scope trace looks to make sense with what is going on. It looks like a big sine wave that has been inverted part way up the pos slope and the sine pulse rides down and back up - same on the neg part of the wave. My thoughts are the magic is in that quick reversal, but could be wrong
Back to work i'll post more tonight, mostly pics. Oh BTW the reason for the short test is i need to build a better motor support. just wanted to run it long enough to do a quick test.
Take care,
Pneuphysics
Take care,
Pneuphysics
