Hi all, i just wanted to show this interesting effect because the idea has been playing on my mind for a while. Today i decided to put it to the test and it works pretty well. We know that when the magnetic field collapses around the coil, a high voltage spike is created. To me this is like a normal magnetic field cutting the coil producing voltage but much much faster hence no real current but much higher voltage almost like time compressing the event. I wondered weather putting another coil inside this field collapse would create the additional spikes without affecting the strength of the spike on the bedini coil and im pretty sure this is the case. What i have done is created a new core with the same type welding rods but twice as long so that i can fit another separate coil behind the bedini coil a la Fusion Chip. I have this second coil attached directly to a neon bulb. For now i just short the coil repeatedly while the unit is running.. most of the time you see an orange flash which means the coil is being shorted when a magnet is TDC.. This is not what we want to do as that is situation draws more from the primary just like a generator and causes drag. When i manage to short this coil during the field collapse just after TDC, the purple flash appears. I have included a pic of the coil setup and a small video clip to show the effect.
YouTube - Purple flash on separate coil
