Hi all,
I have a question relating to the image from pg. 55 of the Bedini SG Advanced book.
The image shows the sequence of events when the magnet is just leaving the position
over the energizer coil. I hope reproducing it here is acceptable.
The explanation states that, while the diode conducts in the trigger window defined by the difference in capacitor
and peak coil voltage, current is delivered to the capacitor AND a mechanical Lenz reaction is created against the
passing magnet, weakening its attraction to the iron core.
So, I think I understand the part where one aspect of Lenz's reaction is minimized because the current is only allowed to flow when the magnet
is still almost vertically above the core and so the attraction is mostly perpendicular to the direction of rotation.
What I don't understand is, why does triggering the current at this particular window weaken the magnet attraction to the core?
As the N-magnet starts to leave the core, the current that it tries to generate in the coil (through the flux change in the core) will always
create a magnetic field with S-pole oriented towards the leaving N-magnet, attracting it back to the core.
So in that case, no matter when you allow the current to flow, it should still attract the N-magnet back.
I have re-read this and the section on Lenz's law many times but I'm just having trouble working it out.
Could someone with more knowledge maybe clarify / correct my mistakes ?
T
T
