Hi bytes, thank you!
if the battery is charging like crazy then maybe you allready have self running!
but just for clearence... have you allready tryed without "closed loop" at the bedini charge output versus the generator coil output and compare measurements of one, when the other is onload? to see if you loose power from oneside when the other one is loaded?
how much voltage do your generator coils show without load? are you stepping down to 12V and more amperage with the transformer and going to charge battery, or your put it directly AC to the drive side, in parallel with inverter output?
i have to apologize, I went with the wrong foot... please forgive me, dont like the others to question my goals or beliefs and I made you what i dont want to myself, shame on me!
i judge you and you must be such a good person, because your intentions are very pure and you choose to share, persons like you are special!
here is a circuit that aeron shared... he says that this is the best way to close loop a system, because dont kill the dipole, this way the cap dont see the battery, but the battery see the cap... so will not charge it, but only take charge of it, so the juice system takes from the battery is only what the cap was not able to supply and if it is more power that the system needs to run, you will be drawing no more juice of your battery and you will take the "extra" energy out with a zeenier, or voltage regulator!
in my setup "uncle lenz" likes to mess around, because im using drive coils of 2 ohm in series... and the generator coils are 200ohm (hig impedeance), your winding are "one to one" transformer?
again, thank you very much for all!
hug
Originally posted by Bit's-n-Bytes
