Originally posted by cikljamas
Connect it simple. Source battery to SSG to charged battery. Measure how many amp and volt at source battery, and how many amp and volt at charged battery. See if your is more than 40% or not.
It is very important to know your circuit efficiency.
I don't draw it completely because I am not sure if I can make clear distinction between joint and passing over with the application that I have. I can not use a big picture because I use print screen to get it. I have to cramp it down.
What previous picture means is you build four of that. Connect it all to the same source battery. The first circuit radiant output is connected to R1, second circuit to R2, and so on.
With only one, the efficiency is around 40%.
Don't use any circuit bellow because the connection is wrong!
As an example, here is the version with two:
With three (one is another circuit though)
