Ok guys, im having problem with this circuit. I tested each diode and resistor with my multimeter on diode test mode, I also tested my transistor and everything works correctly.
When I disconnect everything from the circuit and connect the power coil start to the battery + and the power coil - to the battery negative, my coil heats up and creates an electromagnet which then repels my mangets. But when its hooked up to the circuit I get no electromagnet effect or oscilliation.
I have tried different resistances on he variable resistor from 100ohm to 5-10k ohm, nothing works.
I also tested the voltage through the power coil when the circuit is setup and im getting the correct voltage through the coil while using the circuit, so it appears the negative isnt going through the coil and creating the electromagnet effect.
Here is a pic of my circuit.
Any ideas?
Any ideas?
