Hello again. I have had some inquiries about my set up recently. I've spent a lot of time looking for a way to increase efficiency with my self oscillators. In this video, I hook up a tesla pancake coil in series with my bifilar wound coil to generate the resonance and the sharp gradient discharge that creates a vacuum flux. I run the CFL on about .07amps @12.42volt + 0.8694 watts! Around the bifilar pancake coil, I have also placed what would normally be a primary discharge coil (of tesla pancake) made of 1/2" plumbing copper tube that runs around it.
The bedini self oscillating circuit is being tapped at the collector to the neg of the ignition coil. The high voltage + is connected to a 20 watt CFL bulb with the internal circuitry removed and the negative goes to one side of the copper tubing primary of the pancake. The copper primary is gathering up radiant energy in the form of negative current (opposite to a tesla coil) and increasing both brightness and efficiency of the light. This is a win / win situation.
To watch my most recent video illustrating the effects i'm describing click here.
Here is a general schematic of a Bedini self oscillating circuit rigged with high voltage output.
(NOTE: the schematic shown actually has 2 self resonating circuits in it, a mirror image of the left to the right. In video i'm only using one such circuit. Also a neon bulb should be shown at the collector to the emitter of the MJL21194 transistor to protect the circuit should a discharge path to the secondary battery or CLF bulb happen to disconnect)
Thanks for your interest and feel free to comment or make any suggestions.
I am considering putting this set up live on Justin.tv to properly illustrate the extreme power longevity it presents, given that your lighting and charging at the same time.
Love and light to all.
TheDude
TheDude
