    I checked this earlier and you had posted some other stuff and I was interrupted and had to leave for a while now the other info on the coils has vanished. What happened?
    Les
    • Bedini/Cole circuit issues
      @All,
      Not much to report, other than some frustrations with the Bedini/Cole circuit...
      We can't seem to get a grasp of why the resistors are getting so HOT (200+ degrees) and why when a neon is attached across the transistors, one side will flash! Do these issues have something to do with each other?
      Here is a video showing what is going on...Bedini/Cole circuit issues video
      Real hard to run any prolonged tests until we can figure this out! HELP!
      Thanks, Brent
      P.S. Oh and BTW, the circuit doesn't get even remotely warm on a smaller coil nor do the neons flash. What are we missing? Bigger switch? More transistors?
      • Hi Brent,
        The resistor values that you have in place now are for smaller wheels. The values that Alex suggested in post #1589 will work for your 6' wheel. I've included a picture of my motor board with the higher value resistors 3.3K and 2.7K both 5W and I have no resistor heating problems on my 5' wheel. The board layout is very close to what you and Scott and I worked out, much thanks to JB for letting the conference participants take a peek under the hood.
        You will probably want to add an additional set of transistors to help carry the load and maybe take a look at some base resistors to balance out how hard the transistors turn on. Are they beta matched?
        When I first fired up my wheel I felt like the transistors were staying on too long so I reduced the timing pulse width by moving the hall switch away radially from the center of the timing magnets. It helped with the current draw and I still had plenty of adjustment for RPM.
        Thanks again for sharing, Ron
        Give me a call if you have time
        • Exclusive To Conference Participants??
          Brent, Ron and others that where at this years conference.
          Why is it that no schematic??? Nothing has been
          shared with this group that I know of, on the infomation for this
          thread. Did I miss all that?? We put up all kinds of pictures and
          videos from the first conference. Is there nothing to share. We can't
          help you trouble shoot your problems if we don't try the circuit.
          I would tend to agree with Ron, about the hall switch and the On time
          being to long. That was one reason I started to use a Opti switch.
          I have been able to get the draw down to about .05 amps (no heat at all)
          and still have some charging going on/ plus I am back charging the run batteries,
          some as well. This is all to get the system tuned to the set up I have. Then
          I will slowly open the slot for the Opti switch and get the RPM to charge and
          balanced it out some more. As it charges much better with a slightly longer
          On time.
          More at a later time.
          Mark
          • Originally posted by BrentA929 View Post
            @All,
            Thanks, Brent
            Do you guys still have that scope?
            You are definitely pushing your transistor bases to the max if you are seeing that type of heating.
            I have a feeling that John (correct me if I'm wrong) wasn't running his transistor bases that hard. You should look at the waveform of the coil on the scope and decrease the base resistance while trying to match John's waveform.
            @Rl2003
            I have some photos from the conference. Give me a little bit and I'll post them.
            • Schematics
              Hi Mark,
              I think there is some reluctance to post the schematic (motor control and comparator cap dump) based on pictures taken of JB's Bedini/Cole circuit that he had at the conference. He may be selling motor control modules based on the "highly modified" Bedini/Cole circuit so we don't want to compromise that effort but there is great value to experimenting with this modified circuit so maybe JB would allow sharing the circuit between members privately.
              JB checks this thread regularly so perhaps we'll hear from him.
              Ron
                @All,
                Thanks, Brent
                Hey brent,
                Does it heat up with the old scr pulser? If not I would say the problem is that
                your fet's are not properly isolated from the rest of the circuit.
                Take another look at page 47 of your FEG book and never forget this one little equation
                JOHN BEDINI :== Pure Genius
                Also take note Brent that the h11d1 is fully capable of driving the fets without an extra transistor.
                I ran some tests on my circuit and I wish I could get a vid for you but I have not been able to replace my camera.
                Les
                • Bedini GT3 "Junior"
                  @Ron,
                  Thanks for your most recent explanation. I was hoping to get some different resistor values today, but have been to busy. Will have to wait till next week...
                  @Alex,
                  Sorry we didn't take your suggestion earlier when you recommended it. Part stubborn and part lazy! Anyway thanks for your help!
                  @Mark,
                  I'm a little surprised too that no one has posted any photos from the last conference. Maybe someone will post some soon! We didn't get very many good ones...
                  @Dave,
                  Yes we still have the scope. I agree, we are probably pushing the transistors to hard and will try some new values next week. I have a few ideas and will definitely try the scope idea...
                  @Les K,
                  Yes, that last video is with the SCR zener LED dump circuit. Hope to have the comparator circuit on the big wheel next week as well.
                  Did I leave anyone off? Anyway, thanks guys for all your help! It is nice to be apart of such a helpful bunch. Now, if we just weren't so ignorant when it came to electronics! Still learning...
                  Brent
                  • Comparator Circuit
                    Hey guys,
                    Just a little test we ran on the comparator circuit...
                    Here is a video of what we did.
                    Enjoy, Brent
                    • Solar Panels Run Comparator
                      Very Cool! You guys get to do all the fun stuff. I'm not far behind.
                      Ron
                        Hey guys,
                        Enjoy, Brent
                        Hey Brent,
                        Good stuff. Very similar to my solar setup. What size cap are you using?
                        John K.
                        http://teslagenx.com
                        • John K,
                          We just used the cap off our big wheel. It is a 17000uF cap. Probable over-kill, but we just wanted to try a few things. This being our first experience with solar panels, sure makes you very dependent on the weather. Cloudy days will really bring you down! Ha!
                          Brent
                          Originally posted by John_K View Post
                          Hey Brent,
                          John K.
                          • Coil Winder?
                            This may be the first time a Bedini Ferris Wheel has been used to wind extra wire on its own slave coils. With the welding rod cores and support plates glued in place I couldn't use my small lathe for winding so I was looking for an alternative and realized I had the perfect winder right in front of me. A short length of ABS pipe, duct tape, spacer's and a little TLC did the job. I did increase the wheel RPM to speed things up.
                            In the pictures you will notice a load resistor across the 15,000uF cap to hold the voltage measured at the the cap to around 30V. With just the center coil hooked up the current draw from the power supply is 600mA @ 36V. With the slave coils also hooked up its around 800mA @ 36V. Wheel diameter is 5 feet.
                            Next up is JB's comparator cap dump circuit.
                            • Email
                              On time.
                              Mark
                              Mark, check your email on this forum.
                              Ron
                              • Got it Ron,
                                Nothing new to post yet, but I have picked up some new wire
                                to start some larger coils. I should be able to post some results
                                of what I learn once I get it all wired up.
                                Mark
