Bedini GT3
Hi Mark P.,
Good work. Do you have an analog ammeter so you can see the needle swing back and forth?
Increasing the RPM will reduce the current draw as the amount of time the timing wheel magnet spends over the hall, so the coil will not be on for as long.
As a test can you hold the rotor so the coil is on whilst you have the ammeter on the input and measure the draw current? Just long enough to get a measurement otherwise things will start heating up. Once you have that disconnect the coil from the circuit and briefly connect it to the battery and ammeter. You should get a similar draw current reading. This will tell you how well the circuit is switching.
Only one of you LEDs is lighting. Have you checked the one that is not is not backwards or faulty? Also which way have you got the Zener connected? Can you post what voltage the cap is dumping at? When running mine at 36V my cap dumps at 42V about 3 times per second. I am using 2 x 6800uF 50V caps in parallel.
I don't have my slave coils done yet as I'm waiting on some wire to wind them with.
Keep playing with the timing, you should be able to get it to self start if you position the rotor about half way between magnets and give it a tap in the opposite direction. As soon as the hall fires it should kick the rotor magnet the other way and slowly come up to speed.
@John B,
Is there any chance that you could post a scope shot across the main coil? I would like to see your square wave and duty cycle. I think I ammmissing something and seeing the waveform will clear up what I think the duty cycle should look like. Thanks.
John K.
Hi Mark P.,
@John B,
John K.
Originally posted by Rl2003
