  • #91
    larger pic
    larger pic
    • #92
      different configuration
      from the pictures, JB setup is different from Ed, much less magnets.
      I supopose the EMF field are set @ 22.5 degrees each, the collection field is 45 degree arc but I guess it is best to collect inversed energy from the helix below. Did someone take time exposure Kirlian photo of John's Machine?
      Ed is vertical and John is horizontal allignment.
      JB is lower frequency, different confiqurations is possible as long as it conforms to Phi?,
      what frequency do you need to nullify gravity?
      • #93
        There is a picture of the moon pool, at code144.com. it has 16 ripples or waves that surround the pool. a star of david in the middle. resembles the big motor. Have not found the significance of this though.
        • #94
          link please
          can't find the picture, link please?.
          did john purposely optimize his wheel as a Schumann Resonance negative ion generator by tuning it to earth frequency?.
          if it is OU that we want, or Anti gravity, what are these frequencies?.
          Is anyone building?.
          16 rays. from the 2 squares forming star of david from top view. A star tetrahedron is a three dimensional Star of David
          Are we dealing with 3 dimension or 4 dimension?. A four-dimensional dipyramid based on the three-dimensional square dipyramid with its two apices in opposite directions along the fourth dimension. It has 16 cell.
          • #95
            Hi energy I see aaron opened a new thread called: code 144 john depew and coral castle. Lets move this conv and any one that doesnt really have to do with this device over there so this one doesnt go in the twilight zone. When things get off on a tangent at this place they really swing into left field sometimes.
            I posted a link over there to the moon pool picture. Thanks
            • #96
              Sheild on Centre coil
              Mark,
              Think, the rods go through the bottom, now think what happens when you break a magnet into smaller pieces. Can you have a south pole and a north at the same time from one magnet where the shield intersects ? The rods are 2 inches down into the wood. you only need the coil form bonded to the shield. can you have a smaller south and a big south?
              John
              Hello John
              Could it be that where the shield intersects becomes the Bloch wall area of the core? Does the sheild not draw magnetism in through the bloch wall thereby strengthening the field in the centre core?
              My terminology might be a little off but you get the drift.
              Just my 2 cents worth
              John Smith
              Don't rush me...I am thinking...
              • #97
                As a product of 2 x 8, it is the positive evolution leading to an increasingly tight sequence in the cycles of nature.
                The sum of the four first odd numbers (1+3+5+7=16) which, by theosophical addition, gives 1+6=7, the sacred number.
                And mostly 16 is generated from the Star.
                If you overlay two stars of David / with the four corners of the Pyramid
                you have the 16 points, all in balance. Not to mention the code, 7129 6105195
                Which happens to be my phone number...HaHa..just a little funny.
                "Dont forget to Ring Twice"".
                "I'm thinking that the more "nodal points of resonance" one can find, within relative proximity (of space and time), then the more that can be potentially "done" in that 'area' with respect to "tapping or using" that geometry. These "nodal points" would be, for example, decimal harmonics of 'Matrix-valid' numbers, including gematrian and gematria-related numbers. Possibly, this would 'enable' such things as lifting tremendous weights, or other seemingly "superhuman" feats. " Michael Lawrence Morton
                Have a Blessed Thanks giving everyone.
                Mark P
                Jeremy,
                Yes John Depew is right and so is code144.com this is the way all energy works, the unseen forces that surround us every day, the sixteen poles is the best as soon as somebody figures it out here, I'm waiting for the answer.
                The wheel represents something very important.
                John
                • #98
                  360/16=22.5 only .5 from 23. .5 x 16= 8 8 x 2=16
                  • #99
                    Code 144 & Jon Depew - Coral Castle
                    Aaron,
                    I will tie this all together when the question I asked is answered.
                    Then we will play with code 144. If this is ok with you.
                    John
                    John,
                    That's fine with me. I'll close that thread for now until you want to
                    get that conversation going. At least everyone can see the links for the
                    sites and can start contemplating it.
                    RPX & MWO http://vril.io
                    • Big Bedini Motor
                      OK,
                      ED's wheel we can get into later as Aaron said in his last post. The answer was the Sweet Sixteen, the Sixteen Magnetic Streams from the Sun.
                      We will just move on as I do not think people can follow this. I muss discuses this with Aaron in private because of the nature of it. AS I said it will drive electrical engineers crazy.
                      John
                      John Bedini
                      www.johnbedini.net
                      • @John
                        John,
                        I'll give a call - can probably come out before the weekend.
                        • 16 magnetic streams
                          Please continue,
                          Can you tie it all up, the sun radiates 16 important magnetic rays. We human also contain these 16 Phi nodes as reciever?.
                          Why did you choose 22.5 - 0 - 22.5 degrees. How does this tie to the magnetic concentric arcs ?. Can you define the correlation of the Gates and the electromagnetic effects only appear that are 45 to 90 degrees to the magnetic field.
                          If 0 is the Gate then Tesla has been telling us along, You know why he insisted everything be divisible by three?
                          Alternate 1 for what you don't see (linear methodology) and all is divisible by 3 even Sweet 16!
                          Could your Wheel be set up as Solid State with electromagnets?.
                          Ed riddle - ring twice. 2 coils @ 22.5 degrees ringing @ same polarity
                          collect below - 1 collector coil @ 0 degree collecting inverse energy @ opposite polarity. Alternating Fluxgate solid state, increase frequency for other effects?.
                          • Big Bedini tor
                            Aaron I want to read something to you if you can give me a call
                            John
                            John Bedini
                            www.johnbedini.net
                            • Mr. Bedini,
                              Here is an interesting quote I thought you might like. The author of it speaks highly of you.
                              "Some researchers are looking for a "particle monopole". No such configuration exists, as it is a contradiction in terms. Every attractive or repulsive force has a spherical radius, The center point together with the radial circumference of its force field define a condition of two poles." -Aaity Olson-
                              Andrew
                              • first experiment recommendation
                                take your monopole single coil machine and use the Bedini/Cole switch then shape the field of the bottom coil like I did. Do the timing wheel right use a hall and collect everything from the switch to the capacitor and dump the charge in seconds according to the charge rate, you will see.
                                John B
                                Most people should be setup to do this without many modifications.
                                Just the shield and switch. Should already have a rotor mounted, etc...
                                Looking forward to the first posted experiments based on the above advice.
