  • Well I just spent the last couple hours in the shop fashioning a nice 1/2 plexiglass timing wheel and laying out the angles for the magnets. I quit for the night and come in to check this forum and I just missed John say that an optical switch will work..O well it will this go nicely on the next size up..
    I would say the three coils remind me of a gate. I will have to rest and watch this some more to try to get my mind around it.
    Mark P.
    • Body FET
      Originally posted by nvisser View Post
      I got a fet pulsar to work on a 12v system. The circuit is between the 2 negatives. It dumps the cap (14500uF) when it reach 25.2V. The caps in parallel with the opto led and the gate , determines the on time. Without them the circuit will not work. The pulses are 1.5A nearly twice a second but that depends on your input which is the real important part of this thread.
      The fet needs a heatsink and for bigger systems we need to put more fets in parallel like in John's patent and we will have to clamp the gate voltage to 18V some or other way.
      I will post a short video later.
      Here is the diagram.
      John please let me know if you have something else in mind and some clues maybe.
      nvisser,
      Not sure how you got that to work as the direction of the arrow on the body diode lets the current flow from the cap to the battery with the FET unpowered. At least it does that for me and the cap doesn't charge up.
      This calls for back to back FETs.
      Ron
      • Mag Amp Control
        I want to discuss the principle of rotational magnetic amplifiers. I had to experiment with this principle, so I tried this....
        • Take four wires, any size, but keep them same length and size for now. Keep this simple.
        • Wind three wires as a trifilar coil and the fourth one by itself. The trifilar will be the Mag Amp. While the separate coil will be CONTROL. MAKE SURE TO NOT LITZ THE WIRES OR THIS EXPERIMENT WILL NOT WORK!!!
        • On the Mag Amp coil, connect one power strand end to the top of the next power strand. This will be two power strands in series!! This will create high inductance on the windings!!! Measure the inductance of these windings and keep the LC meter connected.
        • Now short the third available winding on the trifilar and measure the series inductance. It drops!!
        • Now take the third winding ( control strand ), place it across a 9 volt battery and measure inductance.
        • Flip the polarity on the 9 volt. What do you get? A gigantic inductance rise or lowering of the series power wires depending on 9 volt polarity. You can swing the inductance either way dramatically with very little input.
        • Now connect the 4th single strand coil left to the third control winding instead of the 9 volt battery. This extra coil should be in PARALLEL to the control winding of the trifilar mag amp. Think of this as the impedance matched slave coils on the sides.
        • Take a large Neo and slam it on top of the slave control winding! Guess what, you control the inductance to the Mag amp coil very easily!!! Both up and down!!! This all requires an A/C wave to control the inductance!!
        Why is mag amp technology a lost art?! It's beyond me. BTW, the early marconi stations were based on Tesla's work with intense grounding (bolinas county, CA) uses Alexanderson's mag amp work!! I find this very interesting. Read Alexanderson's patents. Some of the earliest work of mag amps.
        So here is a proposed wiring of the Mag Amp with Slaves windings in parallel. I have moved the diode close to the switch.
        There is still lots of room for improvement here. For example, I do not show the capturing of the reactive impulse from the slaves as well as the axle generator. But this is a good start for all of us to begin and understand the process here. Thanks goes to Vissie and Matt for the SSR potential inverted switch. This sche is set for 12volts but can easily be set to higher voltage inputs and outputs.
        Now imagine the Mag amp coil is pulsed in low inductance and released in high inductance!!! A rotating wheel self biases the mag amp, and still only requires one switch from the input!!
        Here is a simple timing of the slaves vs. master mag amp coil in CCW rotation, just to show this principle of variable inductance control from rotation.
        Now everyone needs to see the scalar south (fake south) that is pointing out in between the neo-tipped weak north’s. This is where the triggering of the hall switch needs to be. Since the neo is creating an asymmetrical large south compared to the north, the scalar south is going be very pronounced. Also the rotation of the neo causes the south field to cover a much larger area between the 22.5 degree sections. I or someone soon will talk about this later. This gets into geometry of the axle in generation mode to prevent lenz law!! Look at the sweet 16 diagram from John Depew that John posted, you should see the coils in the center now!! Also notice that the pie shaped barium ferrite magnets are pointing directly at these monopoles!! Ring the bell twice!! Look at the line at the 16 pole sun. We all need to see how to prevent lenz's law with the 10 coil axle.
        I trust that this is mostly on the correct path John. This is by far the most important device to understand how to manipulate and make a man made flux field from Ed’s work as it is correct.
        Hope this helps.
        Jeremy Burnum
        • Originally posted by jerdee View Post
          [*]Take four wires, any size, but keep them same length and size for now. Keep this simple.[*]Wind three wires as a trifilar coil and the fourth on it’s on core. The trifilar will be the Mag Amp. While the separate coil will be CONTROL. MAKE SURE TO NOT LITZ THE WIRES OR THIS EXPERIMENT WILL NOT WORK!!![*]On the Mag Amp coil, connect one power strand end to the top of the next power strand. This will be two power strands in series!! This will create high inductance on the windings!!! Measure the inductance of these windings and keep the LC meter connected.[*]Now short the third available winding on the trifilar and measure the series inductance. It drops!!
          This is exact same test that I preformed, which resulted in the exact same swings in inductance that you are noting here!!! I mentioned this in a previous post, its awesome seeing that someone else (you especially) has found "the ideal" use for this phenomena!!!
          [*]Now take the third winding ( control strand ), place it across a 9 volt battery and measure inductance. [*]Flip the polarity on the 9 volt. What do you get? A gigantic inductance rise or lowering of the series power wires depending on 9 volt polarity. You can swing the inductance either way dramatically with very little input.[*]Now connect the 4th single strand coil left to the third control winding instead of the 9 volt battery. This extra coil should be in PARALLEL to the control winding of the trifilar mag amp. Think of this as the impedance matched slave coils on the sides. [*]Take a large Neo and slam it on top of the slave control winding! Guess what, you control the inductance to the Mag amp coil very easily!!! Both up and down!!! This all requires an A/C wave to control the inductance!!
          WOW!!! You just took this to a whole new level!!! Thank you!!! Being that I am already setup for it, I'm going to test these new "control" methods that you mentioned, I am especially excited about the AC version.
          My only question is; is the fourth strand really necessary? I guess I'll know soon enough....
          Good stuff.....
          • Big Bedini Machine
            Try to follow me through here I'm giving three answers with questions.
            Mathew,
            Very good post and very close to solving the machine, however you guys really need to put your thinking cap on now. What have I always said about devices since we only use them one way. Also your right on positive electrical science, "the waste product". Think about how these coils are discharging,
            Also good Jerdee, great theory, however what is the downfall of the switch? and how is it wasting power?
            Also Redrichie That is real good.
            I know Ron Cole's notes were never published here on inductors but what would happen if the inductors were not all equal but were in parallel as Ron's notes indicated the current would not increase, only by a fraction that drove GE nuts and what about the two extra windings if they were held at a bias voltage inside. Would you not get the coil discharging at different times.
            Three coils. what do they make up geometrical wise?
            The capacitor is used in the positive domain and where is the spike really going but by the capacitor in the negative domain is it not going where Mathew said.
            Just being sopped up a little at a time by the capacitor since the capacitor does not know what to do with it. Is it not in the circuit to keep the bi-polar switch from cross conduction on the devices, you have a full complementary amplifier in that circuit. I said the diodes must be right on the switch rails. right at the coil
            I have some real thinkers here GREAT!!!!!!!!!!!!!!!
            John B
            John Bedini
            www.johnbedini.net
            • Wow!! Jeremy.
                Redrichie,
                Ring the bell twice, then the energy long pulse.
                Depends how your looking at it, but two short one long return energy pulse to drive the star.
                John B
                Originally posted by redrichie View Post
                So Like john says, why does he need any switch on the output. He doesnt. He also said he fires the pulser 3 times a second I believe. Watching the video, it appears that the bottom coils fire (in parallel) one right after the other, pulsing the next incoming magnet, as the magnetic current flows through the coils. right at about three times per second.
                So the pulser fires and opens that flood of energy every time the magnets induce the spike in the coil? is the switching for the pulser done at the timing wheel, with the halls, or is is that definitely for the hub portion?
                I was not able to attend the conference. If I am out of line (or league) by asking here please someone let me know. I am just trying to learn.
                @John
                When using the plates to shape the magnetic field of the center coil, does the angle of that plate correspond to the Masonic upside down delta symbol (sacred geometry/square and compass)? Or is that angle there purely due to the outside slave coils length?
                Watcing the video clip there is a long pulse as the magnet passes over the plate/coil/plate then 2 short pulses as they pass over the outside coils. Correct?
                John Bedini
                www.johnbedini.net
                  Interesting.....
                  Well if we join the ends of two neighboring windings, we end up with a triangle, which is the Greek symbol for "Delta"... which is a standard connection used in AC motors and generators..interesting....the triangle can also be related to the the tetrahedron.
                  Is this what you were looking for when you asked: "Three coils. What do they make up geometrical wise?" If so...please elaborate!! If not....please elaborate!!
                  • Tetrahedron
                    erfinder,
                    I think you are right about the tetrahedron:
                    Tetrahedron - Wikipedia, the free encyclopedia
                    especially this part:
                    "Electricity and electronics
                    If four equal resistors are soldered together to form a tetrahedron, then the resistance measured between any two vertices is half that of one resistor.[8]
                    Since silicon is the most common semiconductor used in solid-state electronics, and silicon has a valence of four, the tetrahedral shape of the four chemical bonds in silicon is a strong influence on how crystals of silicon form and what shapes they assume."
                    We have four resistors in the 3 coils (all in parallel), has John configured them to form a (non-linear) tetrahedron?
                    Also, what do you see in the attached picture? (Star of David) I think I can see the geometry of the 3 coils.
                    Or I could be barking up the wrong tree
                    John K.
                    Originally posted by erfinder View Post
                    Interesting.....
                    http://teslagenx.com
                    • level
                      Those videos are incredible and I think he has a lot of things right
                      with the numbers. However, with the comparison to the lodge, he is
                      completely wrong on almost all of it - STRETCHES - he has no idea
                      what he is looking at in there and is completely making it up.
                      That is an ancient LEVEL in the middle of the sun and NOT a bell,
                      I guarantee you that. There are countless other stretches in these
                      videos.
                      Anyway, the comparison to the Lodge is irrelevant - he seems like a
                      wiz with the mathematical part of it and doesn't need anything in the
                      Lodge to match it in order for him to prove his point, IF he is right and
                      it is the best decryption of those numbers I've seen on any of the
                      Leedskalnin mysteries.
                      Those lines on the pyramids is the ascent in the great hall in the
                      GREAT PYRAMID to the King's Chamber! IF the dot at the end of the line
                      ended at 1/3 from the base, which it looks like it did.
                      In any case, I loved those vids for what he put together and don't want
                      to take away from it, but the Lodge comparison just has to go because
                      it is false.
                      Anyway, it is 3:14, which is pi or 22/7 so I got to get to bed!
                      • @ John B.
                        I see what your saying on the pulse train. at least to lighting the light. So the shield is really an inverted bell? shaped very similar to eds magnetic curvature symbol. Mr. Bedini, did you just make a model of the Atom?
                        John K.
                        There are only 8 coils in that picture john has 10 in the center. Unless john is using 2 (ring twice?) of the coils/magnets to pulse half the coils in the center to counteract the Lenz in the bottom HALF of the machine. (this is not two separate machines but one. I think it needs to start being thought of in that way. ) It would def make up the 8 point star all over the place at coral castle and code 144.
                          videos.
                          it is false.
                          In my opinion the comparison made between Coral Castle and the Philadelphia Masonic lodge that Jeremy of Code144 shared with all, may not be entirely accurate, however, the points made, however far they stretch the imagination are relevant whether the points are correct or not, these are the directors impressions! They were/are relevant to him! The message he prepared was so important to him that he felt the need to share it. Honor should be given where its due, whether the content is flawed or not. If we as viewers of this information know for a fact that some part or parts of the presentation aren't factual, then it is our duty to not only point out that flaw, but to also provide the correct answer, preferably immediately following pointing out the error.
                          At the end of the day, no one save a Mason in the know....is in the position to verify or discredit the story which has been presented by Code144... Now if the stories we hear about that group of individuals (Masons) are true, we won't see one on these pages telling us whether the information provided by Code144 is accurate or not. That being said...The Masonic connection deserves some attention as well...but now is not the time nor place for such a discussion....
                          redrichie,
                          I think its the tetrahedron, John only asked about three coils, so I don't know how one would get the "Star of David" out of a single tetrahedron, or three windings. If there is a way and he knows it, I am definitely all ears for that one!
                          • It was early when I typed my last post. I may have not thought it out all the way before posting. But in the axel there are 10 coils. if 6 were the star that would leave 4 left over . 2 for each set of 3 coils/ magnets. basically I am thinking that the axel is is doing the same thing as the bottom, but doubled to make up for itself? Ramblings I know. and I should have waited for clarity before I posted the last post. Appologies.
                            • Im Happy to see Bedini again with his new device, proving that free energy is possible.
                              a better future is possible with this technology, i'm so happy, it makes sense to my life, thanks John, you are a wonderful person, and i love the "old pages", all the things one needs to build one free energy machine are there.
                              Pd: i love the music too
                              • Ha... I also liked that song (and everything else). Way to go signore Bedini.
                                Best
                                Alex
