If your cell needs water to keep it alive then your cell is more than likely a water battery. If your cell can't maintain over a volt without adding water for a month than its more than likely a water battery. If your cell looses most of its voltage after freezing it for more than 24 hours in your freezer than its more than likely a water battery. If your cell is constantly loosing voltage over time after you have made it but heating it up or getting it wet again brings it back to life than your cell is more than likely a water battery.
If your crystal cells turns out to be a water battery its not a bad thing, but water batteries don't last due to them corroding so the water battery will die much sooner than a crystal cell. I do incourage others to make a water battery so that you know what to stay away from when making a crystal cell. I do strongly recommend we stay away from water batteries and keep focus on Crystal cells. In a crystal cell what you want is a cell that gives a constant voltage with no load after its been made, does not go down in voltage over time with no load and bounces back to orgainal voltage when a load is removed. A cell that shows no corrsion, and a cell that does not need water to keep it alive is key to a crystal cell.
