@all
I've taken the big crystal cell and put a couple coats of paint on it so it will be protected from the moisture in the air. I'll have a picture below showing the cell.
The big crystal cell is nothing more than a Crystal glue cell ( Elmer's glue, Epsom salt, and Salt substitute) with a lot of magnesium ribbon wrapped around a copper tube. I then allowed the big cell to dry for a couple days and then I've spray painted it in-order to protect it. I never believed in charging the cells with a battery as it seemed pointless, so i never charged the big crystal cell. Scaling up is key, more surface area is key to power. The big crystal cell is still maintaining its power, but I'm going to allow it to dry some more and then do more readings. If you're going to scale up avoid cup like things or anything that can trap water and take longer to dry, use plates or pipe and any open ended thing.
I'm also testing out an idea that combines the Crystal glue cell and the stove top cell into one. Since those are the two cells that do the best I figure I should combine them.
