@Ib2:
I know what you are going through, and I empathize with you on that.
It is no coincidence that Hutchinson, Bedini, and others have used two different types of salts in their mixes, also. But, you are the inventor of the Epsom/salt substitute mix. This comes after much trial and error on your part, and you've proven your point, by making the cells and showing many videos on how they can work, even for a long time, without any additional water added. This is no small matter. Others that are new at this should really replicate the cell mix to a Tee, before you make an untested judgement. The salt substitute that you are using is the best to use in your salts mix, because it has been shown by you that it works, and works very well. Others have used Epsom/Rochell salt mixes, because they have also found them to work well.
If anyone else can obtain over 1.5 volts from a cell made of only two short pieces of wire, and some salts, then we'll be all ears.
I see that two different types of carbon in a cell, also seam to work better than just one type by itself. This may have to do with the same thing, two different electronegative potentials, even in the different types of carbon used, as they are not all the same.
I really advice people to use carbon when ever possible, as it will eliminate at least 1/2 of your cells oxidation problems.
Jim has made carbon/Mg cells that can output almost 3 volts, each cell, at least at first. So far, that takes the cake...
Guys, seriously,
thanks for all you do.
Guys, seriously,
