Here is a picture of my newest cells. The bigger one on the right side is a semiconductor cooper/Al treated cell, with a plug on top to add water. If I plug the cell up, it will still seep the hydrogen gas as well as salt water around the edges of the cells. So, quite a bit of pressure is created by this gas that needs to vent, and also needs to be neutralized by a de-polarizer.
Hi all, I just finished cooking my new cells with the depolarizer (mn2o3) and the heated pyrite (fe2o3). Now and so on it will be a waiting game to see how long the led will light without water and without destroying the magnesium. Hope to see some progress over here....
I am not sure who all have tested or tried cry cells?
I know Ibpointless has made some
What can we expect from dry cells in the way of power
I have some that still get great volt 1.5, but the amps are way down 5Ma
Can some one tell us what to expect?
Have you tried putting some cells in the freezer over night?
The video was very interesting, i like how you add the water but is that what i think it is that separates the metals?
I have tested the cells that I've made yesterday and the mn2o3 is destructive. Forget about it!! The new ones today: Oxide treated copper caps, mag bars, 3 spoons rochelle salt, 1 spoon epson salts, 1 spoon sodium silicate, mag filings, silver filings, calcium carbonate filings, iron pyrite, galena, cruched pink tourmaline. Cook on the stove until nothing happends (no sounds from the cells). The cells gives me 1.4/1.5 volts standing and 4/5 ma shorted with a 10 ohms resistor. The amps shorted out drops then rises sharply after. The voltage than bounces back to where it was. I think these are the winners!
Ibpointless was all right about the water. I'm now sure that water is needed but just to start the chemical process of new materials on the electrodes. After this long process, a new type of converter is created. The iron pyrite and galena are sulfides and these sulfides, with the help of the water and the salts ''creates'' copper sulfides on the copper. The rectifier is then etablished. On the magnesium, magnesium carbonate is formed and protect the magnesium WHEN DRY ONLY. Thats my theory...
John Bedini talked about this a while ago to protect the magnesium from corroding and this coumpound can take a lot of potassium ions to gives us more energy output. The trick is to make it. Thats the hydrate #5!!! Burning magnesium filings will give us the magnesium oxide (2MgO). Then, heating this oxide with sodium silicate to obtain the coumpound. I found somewhere that a new crystal structure evolve with temperature above 750c. I will try that.
