Originally posted by ibpointless2
I don't know if you have seen my last video, but this is the oldest cell I have continued to work with
It is a dry cell and still has power and the volts just keep going up
It is sitting around 1.5 Ma, no matter what I do to it, it also gains Ma when I short the cell, but when I did my test it almost hit a 1/2 amp
I have several theories and I was wondering if you could help prove a piece of the theory
You have a cell that is a copper pipe wrapped in mag ribbon
If you could do a test as a base line volts and amps
Take the tape off the end of the pipe and put ice down the tube, then blow the outside with a hair dryer, if my theory is right then you will have massive gain in power, we are making a form of a thermal electric generator
But there is a twist to this, which leads to the next test after this if this proves right
PS, make sure you do not get the mag wet or this will not work, the cell needs to be dry
Another PS, If this does not work, you may want to try hot water in copper pipe and cold on the Mag
Best of luck
