Bedini Earth Light
  • #91
    New cell
    @ John B.
    If you need me to post new video send it to my e-mail, and I will post it for you... if I can....
    • #92
      Earth Liht 6 Volta Pile,Carbon Magnesium
      Earth Light 6
      Here I explain coupling the cells together to form a Volta Pile. It is very important the way you hook them together to form the potential your looking for. Also I point out how when the Alum forms a crystal on the outside of the Carbon Magnesium Battery it does collect energy and does run the Monopole iron-less motor.
      YouTube - Energenx's Channel
      This Volta Pile shows that you do not need current to run Led's and small motors.
      It's funny to see things off subject as My circuits have nothing to do with The JT circuits, as I have always used open loop circuits to use anything other then that is to defeat the purpose of energy from "Zero Point". The JT circuit is closed looped and follows all conventional thinking, you do not want that with earth batteries or crystal batteries.
      John B
      John Bedini
      www.johnbedini.net
      • #93
        @John,
        Seeing you're adding pressure in Video 6 and you already have a temperature difference between carbon and mag., maybe try crushed Tourmaline powder/spray on your felt. Tourmaline is piezoelectric and pyroelectric...
        How to Use Tourmaline Powder 400 500Mesh - wikiHow
        Just thinking out loud, thanks for sharing you videos.
        rw
        My Calloway V Gate Motor Video
        • #94
          Magnesium rubbed with mercury
          Hi All
          I made today another battery, same construction as post # 59 but this time sanded the magnesium with fine sandpaper and then rubbed the cleaned magnesium with mercury. It’s difficult looking at the magnesium to see if it has changed the surface or not - maybe it’s more shiny after rubbing, but there is no dramatic indication that any mercury has been absorbed.(Does anyone know how you can tell?) At the moment volts are 1.4 and amps seem to start at 10ma then, after a few minutes climbs to 30ma and stays there. On my first battery, black lines/corrosion, has appeared in the centre of the magnesium strip, so will update in a few days on wether the mercury stops the corrosion.
          John.
          • #95
            Youre correct
            @Chuck H
            I know what you mean about having all these experiment going on at the same time. I am running out of clip leads and my wife says that the house is looking like a toy store. There are all these whirling things and lights on here and there. This battery project brought on a bunch of testing with mixed results. Some of the things that I have tried were truely amazing.
            John B you have my head spinning with the Alum and crystal part of this. The more I got into it the more questions it raised. The biggest one is-- can we actually get real usable power out of a cell WITHOUT a galvanic reaction happening??? The internet research that I have done says yes ---but the details on exactly HOW are vague. Research into John Hutchison's work was most frustrating.
            ----And the work goes on.
            Lidmotor
            LidMotor
            Yes youre right. Anyone that says a galvanic reaction is NOT occurring here with these Mg/Carbon batteries is either delusional or just plain pipe dreaming, high on the notion of 'crystal cell' myth.
            There are only a few cases of TRUE crystal cells and the remainder of what you see here at the forums is just what has already been accomplished over 100 years ago when battery technology was first emerging. None of what is being attempted here is new.
            Why do you think you have to utilise something as oxidative as magnesium (which oxidises in fresh air let alone once you apply moisture to it!) in order to get some half decent volts out of the cell? If this was a true crystal cell where the crystals were rectifying 'whatever' to create current, you wouldnt need magnesium.
            Additionally, the cell always needs to be moist, so theres your tipoff right away that it is a galvanic reaction and the magnesium will eventually be totally consumed. Just because its not swimming in electrolyte or dipped in a gel like a lead acid battery doesnt mean this isnt galvanic....Gawd. Be scientific and truthful to yourself people!
            Its all a trade-off, low current and NEAR dry cell at very low Mg consumption rates OR increase the moisture OR acidity and watch the output climb. However, the cell won't last long.
            This is no magic fruit here, no matter how slow the decay. Besides, as LidMotor stated, what can it do??? Light a led or turn a bedini wheel REALLY slow. Wow. Not many applications there especially considering Mg isnt cheap in the first place.
            Youre better off focussing on a circuit that can deliver real current and make existing batteries last longer like the joule thief variants.
            TP
            • #96
              Earth Light 6
              John B
              Nice work. I remember reading that in the old days, they used to have problems with high voltage piles, in that it would act as an electrolyzer. It would be pretty interesting to pour water into a device as simple as two metals and have hydrogen come out.
              I've always been interested in Hutchison's cells, especially the 30 volt one. I think he intends to take the recipe to the grave, so it will be up to us experimenters to figure it out. Heck you could hire 1 professional remote viewer and have the ingredients in less than a day..
              • #97
                Earth Light 6
                John B
                John, this is fascinating. Is the oscilating circuit actually part of the crystal building process? Is this what is important about the ring you showed in an earlier video?
                Reading the material you referred us to, I saw a crystal battery about the same as a D size that was putting out 3 amps. Is this really possible with this design?
                Les
                • #98
                  Earth Lights
                  Teslaproject,
                  I did want to answer you as to some of the statements about batteries.
                  I do agree with you about the corrosion factor. I also agree about the galvanic action as I pointed that out early on about magnesium as the air seemed to do more damage. However that does not explain why I have one cell setting here completely dry and it runs my motors and lights without that corrosion factor as you can only have that reaction if you cause the cell to draw current. I have been watching for days now Magnesium not corrode or waste away. What is fruit, fruit only happens when you discover something different from the norm, that is how new inventions appear. I'm not a chemist and never said I was.
                  The JT circuit has nothing to do with what I'm doing so your right draw real current and burn the cell up even faster. You think this means nothing, but it does as we do not need current to charge batteries as I have proven that time and time again. Your entitled to your opinion but this does not concern the Joule Thief circuit as you see me not using it at all , no need to suck the crap out of the battery. I find nothing frustrating about any of this work as this is how we discover things. If you have something better then by all means "spill the beans". So do not take this personal at all but if you have advise and know something we do not then by all means let's here it, I'm open. By the way how many reproduced the Crystal battery without cement and crushed up rocks?
                  John B
                  John Bedini
                  www.johnbedini.net
                  • #99
                    Mercury, Earth Lights
                    Freezer,
                    That is what I remember from school when constructing a zinc battery.
                    Want to see what Mercury can do, do this experiment. Tape down a piece of aluminum to the bottom of a glass jar. then cover completely with some volume of Mercury leave for two weeks. Then remove the Mercury and take the aluminum and put in water watch what happens.
                    JB
                    John Bedini
                    www.johnbedini.net
                    • Earth Lights
                      Les K,
                      I do not know if this is part of the mixture with the radiant energy, Tesla in his later days was working on Crystal lattices to recover energy in the radiant form as he never used the word negative energy. As a matter of fact he never said electrons moving either?
                      Yes I do think that it is possible to have this type of cell. If you try to reproduce the Marcus Reid Crystal Battery it is like impossible with his mixture. Now his voltages are very low but very promising when it comes to crystal lattices and collection of Radiant energy.
                      John H on the other hand will take it to the grave with him. I had that conversation with a very good friend of his, you can forget it, so I refused to let him come to my shop. What we need is an Energy Dam to collect it. I have tried Tourmaline cells just could not get the right mix or the mineral was not the same some how.
                      John B
                      Les
                      John Bedini
                      www.johnbedini.net
                      • Volta type stack using Zinc/Carbon Graphite, and Alum water running 4 LEDS
                        This is an update to a couple of the cells and a new one that looks some what promising. The new cell is a Volta type stack using Zinc and Carbon/Graphite with a little bit of Alum distilled water (8 Carbon/Graphite discs and 7 Zinc discs). It is making 6.9 volts and 200UA and is running 4 LEDS. It is not using an osilator or joule thief type circuit. I hope if the "Stack" matures well it may provide power to run many more LEDS in combination with an osilator circuit (or no circuit of the type if lucky). We will give it a month or so and see what happens... Here is the video.
                        YouTube - Bedini earth light/Volta type stack using Zinc/Carbon Graphite, and Alum water running 4 LEDS
                        • Originally posted by teslaproject View Post
                          LidMotor
                          TP
                          The fundimental mechanism of this cell is being studied.
                          If any principles can be demonstrated no matter how small then
                          crystal cell can be better understood.
                          There is some moisture and alum powder in the felt of the cell is
                          allowing limited polar growth within the dipole,
                          You will need to wait and see how effective John's tiny alum crystals are in preventing magnesium loss while allowing energy flow. A study of AZ91 a magnesium alloy shows remarkable resistance to corrosion and pure magnesium also rates high. (you are not reading so well)
                          Also my own study of 24 cell chemalloy water battery ran a year the led was still glowing strong. I did'nt notice loss.
                          I believe that abundant high K materials are readily available for every human on the planet that could provide some useful power at little or no cost. 24/7 any location. but how can we utilize them? I would like to know.
                          I never understood Hunchington ingredients troll doll idiot, ha ha mystery. Instead of waiting it is better to just do it. thanyou.
                          We should stop and follow the joule thieves for real power. The point is you can't always rely on your battery of the month card. You will need to go purchase batteries lots and lots of them. No sense in squeezing depleted batteries if other sources are available. so battery squeezers are really complaining about inability to understand zero point.
                          The teaching of open circuit must be demonstrated differently
                          because comments are reflecting ambiguity that the concept is not easy to comprehend.
                          In the meantime the small led of hope burns in the Bedini earth light.
                          • Just wanted to post an image of the alum growth. The alum seems to adhere very well to the magnesium. Will let this one sit until the alum fills the entire cavity, and then dry it out.
                            • Originally posted by Freezer View Post
                              Nice Work!!!
                                Les K,
                                John B
                                That relationship between radiant and crystal is mind boggling! I feel strongly compelled to finish the GT3, but man I sure want to start testing some of this.
                                Thanks John
                                Les
