Bedini Earth Light/ Crystal Battery
NickZ,
Silver to Gold already pointed out that the cell that has gone over 500Ma was in the DVD in the energy series and that was a direct short, and if they cant do that I get rid of them. The Crystal Cell under direct short is over 30 Ma. Look it is easy to do providing you have the right Copper and Magnesium and the surface area.
Again I'm going to point out that the cell impedance is the limiting factor in all of this. If you would do the research you would find out that it is also possible to do a lead acid car battery with the mixes your playing with.
Solid State chemistry is much different then normal chemistry do not mix up the two. You change the Crystal structure when you apply heat in any form. If you mix Rochelle Salts with Epsom Salts and add anything else you have changed the Crystal Lattice add an impurity and you add electrons to the valance band, the point is, can you pop an electron out and have something to take the place of that and then add another one to pop out.You kill the dipole and you kill the battery unless you have the broken symmetry, open to the environment, input from Nature.
You are all limited by the impedance of the cell and you cant change that unless you change the mix completely, The Crystal cell is a Ceramic Doped Semiconductor high impedance 1 Meg Ohm, how much power can you get out of that? We are doing real good compared to most doing this research work. Design your electronics to run on it.
John B
NickZ,
John B
