Galvanic Effect
Ibpointless,
Not to be a bigger jerk, but maybe this is all misunderstood right from the start as to why I did the experiment with each Chemical.
I have already taken two of these Epsom Salt cells apart and found no water and no galvanic effect on the magnesium or the copper.
The water in the cell is bound in a crystalline form. So there is no free water. I can do better then that and mount a probe inside the crystal .
Here is what I found,
The Rochelle Salts combined with Epsom Salts and Sodium Silicate does suck in water that is why I said do not use it in the mix. Rochelle Salts is known for that as it has destroyed many Microphones. We can do better then that by making a ceramic out of it with the pure chemicals contained in Epsom Salts.
The cells I have made continue to put out power with heat I check that everyday.
So what your saying is that Hutchinson's cell is Galvanic and will only work for a short time until the chemicals dry completely out, unless water appears again (That means Ionic and no spooky Casmir effect or Zero point energy, just a Galvanic Battery). And that all of the cells including yours will do the same thing?.
Cook some and find the water that is free we all need to see this.
Now did you heat the cell again? See what I was doing here was making a Thermopile out of cheap Epsom Salts has nothing to do with a battery as I could use any metals and get the effect. To tell the truth, I would not make a Crystal Battery this way, But I have learned something here about what not to do.
John B
Ibpointless,
John B
