Any chance you can get a clearer pic of your diagram or in some way make it more readable? Note that you can directly upload it here rather than a site that runs you through hoops to get it. Thanks for sharing.
i posted that question coz im wondering which is better in battery rejuvination, direct radiant or cap pulsing?
As far as the R charger goes I wouldn't have an answer on that but, You can build both technologies into 1 machine and really see something. Takes a little work though.
JB has demonstrated a motor-generator before which gain a speed as it gets loaded, do you know which motor-generator he was referring to?
@anyone
when doing high-capacitance discharge with 2-4 volts above battery voltage, that would mean pulsing a high current in the battery right? so how would then the C20 rate of charging and discharging be applied in this form of charging? i.e a 7Ah batt has only 280mA C20 rate.
