bedini restore batery
  • #16
    Originally posted by blackchisel97 View Post
    FWBR stands for a Full Wave Bridge Rectifier, also known as Graetz Bridge.
    Third winding is connected to the bridge and its pos/neg are connected respectively to the charging battery.
    V
    No, mine is different because my FWBR is used on primary coil, mainly with addition of capacitor. The purposes:
    - make the radiant impure / adding normal electricity
    - to combine two or more radiant circuit output
    - utilization of primary coil.
    • #17
      I built a circuit of two transistors
      When running all the neon glow
      Is this correct?
      grey is no plug tranzistor(plug later)
      curernt draw is 0.3A-0,11A
      • #18
        Is this correct?
        Yes, this is correct.
        V
        General D.Eisenhower
        http://www.nvtronics.org
        • #19
          Hi yesterday I built it completely
          my BEDINI "locomotive" shall consume about 2.4A in max mode
          when the potentiometer to 0 ohm only 100 ohm base resistors ...
          rotor spins very fast .. I feel the wind
          My previous engine had BEDINI consumption 0.18A but not getting into the battery state of charge .. always got it from 10.8 to 11.2V it is still wrong ... Charging time was 2 days
          Bedini locomotive after 90 min was charging the battery at 13.5V.
          break after eight hours battery has 12.7V
          I started discharging 5 watts LED lamp ....
          Thank you all
          and later send video
          • #20
            YouTube - ‪"Lokomotive" Bedini‬‏
            • #21
              i rejuvenate my first batery im happy but battery not have full capacity ...
              batery have only 3 cycle ,, each cycle is battery better ....
              my new idea is solar extracter
              for explanation
              i have Batery 1 (B1) and Battery 2 (B2)
              B1 hat 14.1V
              B2 hat 12.1
              if conect B1 a B2 paralel
              B1 will charge B2 curent 2A (its only for excample )
              my charge performace is 14.1-12.1x2A=2x2=4 wat
              Similar chargin is by solar panel
              i will beeter charge performace than 4wat
              Idea is simple
              On my solar panel connet coil and switching(by transistor) but for example switch
              when switch on coil create magnetic field
              when switch of coil magnetic field colabsing create spike and
              energy flow into batery 2 a charging his
              question is simple i can have beter charge performace than 4wat ??
              switching coil bedini style... maybe joule thief ??
              • #22
                my simple idea
                • #23
                  Hi folks, Hi powers, on your simple idea solar charger, why not just switch one leg or do both legs need to be switched.
                  I wanted to share my experience with trying to bring back my 12 volt 7 AH gel lead acid batteries.
                  Over time they have all been taking a charge, however they are all sitting around 12.4-12.5 volts.
                  So I decided to completely remove as much charge from one of them, once discharged using a 12 volt auto tail light bulb until it could no longer light, I then placed a wire across the terminals to short the battery and remove even more charge.
                  Then I placed a couple leds in series across the battery and let it drain for days, then i placed a single led across battery and let it drain for a couple days.
                  The idea was to re-balance the cell voltage and it worked very well, since the cells were not damaged or overly sulfated, I was able to bring the battery back up to 12.75 volts standing voltage.
                  Now that the 6 cells inside the lead acid battery are more balanced, this battery will give me greater amp hours and with further Bedini radiant pulse charging.
                  I now think I can get all my batteries back to like new or better status, as long as any of cells are not overly sulfated.
                  I am now doing this with all my lead acids to bring them back to there normal voltage.
                  Hope this helps anyone and any comments or questions are welcome.
                  peace love light
                  tyson
                  • #24
                    Hi I added two switches only demonstration
                    for source separated from the coil and magnetic field collapses
                    i have many bad car battery ... cell tip for balance, I would need to explain better, because I do not know English well (... at school I learned German) I am from Slovakia ..
                    pls give me a schematic picture thx
                    • #25
                      Hi what experience you have with the renovation of Li-ion laptop battery?
                      Bedini with?
                      I started before yesterday in the 0V
                      and now the battery has 16V
                      capacity is questionable .. hmmm
                      • #26
                        peace love light
                        tyson
                        Hi Skywatcher, I'm new on this, and there are several things i don't understand. I have my car's battery with problems. If i charge it about 10 minutes, it has enough power to start engine. Every time i need to give charge to put it work. The car was parked about 5 months and this was a problem for battery. Now i want to make something based on your experience. Do you advise me to completely discharge batery and then put it on charge? And about charge, how to do it?
                        • #27
                          Hi herlander, see joule ringer thread and bedini oscillator thread for more information.
                          Though you'll need a decent radiant charger with a good amount of voltage and a little current on the output to start to rejuvenate a car battery. I had no luck with my old car battery because two or three cells were shorted and the sides of the battery were bulged out, so physical damage like that can't be repaired with a charger.
                          peace love light
                          tyson
                          • #28
                            I'm not sure if this posting isn't violating any Forum rules, if so pls. remove it.
                            Due to some financial problems I have to trade some of my stuff. I have tested and working (for the past 3 years) solid state charger with trifilar AWG#18 coil and MJL21194. This is a replica of John Bedini circuit with inverted trigger. Circuit is mounted on wooden base with two digital readouts - input V and charging battery monitoring also, analog input A meter. I can supply pictures. I didn't make up my mind yet about the rotor for 6 coiler and other prototypes. Some can be seen in my youtube channel. I'm not comfortable posting such offer here but I don't have many options left. I can be reached via PM or youtube.
                            V
                            • #29
                              for sale
                              V
                              Post away, you're not a spammer.
                              Pics and other details are useful.
                              • #30
                                Description of devices
                                Thank you Aaron.
                                This is my replication of trifilar solid state energizer/battery desulfator based on John Bedini design. Trifilar untwisted AWG#18, MJL21194, 50A FWBR. I used this energizer with variable input so it also consist of DC/DC converter at the input. Converter maybe removed and used for different purpose. This is 3-27V 5A converter which can be hooked up to either AC or DC source. There is a pot allowing to set at desirable output V. Analog A meter is connected in series with input which allows to determine sulfation or detect shorted cell. Battery impedance will change from high to low during restoration process which will reflect on A reading (circuit will draw less in time). There is 12V 5W bulb in series with trigger winding. Right now circuit is connected withe inverted trigger (trigger wire to positive instead of negative of input source) and it is capable of restoring car battery in reasonable time. Of course it can be changed to "normal" configuration by reconnecting trigger wire. Higher than 12V input will require adjusting base resistance for proper tuning and waveform. Small fan was added mainly for cooling converter part when running on higher input ( > 20V).
                                There is a digital monitoring of input V and charging battery V however, charging battery meter is connected via switch so it will not affect charging process and prevent the meter from being damaged by hv pulses.
                                This is one of my early prototypes of SSG. HD rotor consist of 6 double ceramic magnets epoxied between CD's. Bifilar coil and MJL21194 (which is overkill for this project and can be substituted for MJE3055 or similar).
                                There is an option to charge with negative via 1N4007 from the collector or from FWBR soldered into the pcb. Analog A meter allows to monitor and tune the circuit. When powered from 12V adapter (included) it takes about 200 -250mA. This circuit was built to study pulse charging effect on smaller batteries up to 4 - 7Ahr lead acid but it was also used to charge AA rechargeables in series via bridge. There is a pot allowing to tune in and it skips in one place. It still works ok. I don't have another one to replace it.
                                Both circuits are fully functional and being tested over long period of time.
                                I hope someone could benefit from them as much as I did and full credit should go to John Bedini. I merely replicated his invention.
                                PS. I also decided to part with aluminum rotor. It measures 6" dia x 2" thick/ There are 6 slots machined for double stack ceramic magnets (such as those from Rick). Rotor comes with double bearings and stainless shaft with flange. It can be seen on my youtube vid - tuning SSG with LED. This rotor was quite expensive (over $300) but I'm open to offers.
                                V
