Hi All,
I am currently laying down plans for a rotor and would be appreciative of some advice.
The rotor will be cut from 1/2" Aluminium plate,5 off 2"Dia x 2"L Neo cylinder magnets will be used,the mags will be placed parallel with the axis of the Alloy disc.The magnets will be enclosed in 2" Alloy tubes and locked in place with set screws (so coils will be run not from the edge of the wheel but from the face).
I have two questions.
1/ What distance apart is optimum for these magnets? they are rated 370lb pull and 13,200 Guass. 5 in a circle end on,what pitch circle diameter would be best? I am worried about overlapping fields.
2/ Can i get the same useable radiant spike from the South poles? In using a rotor this way i can use coils on both sides of the wheel and make use of both poles?
Even if i can't use the South poles,i do plan on building a rotor this way as it is easier and cheaper to build a sizeable rotor from plate and tube,less trouble with centrifugal force and mounting heavy magnets.
Thankyou
Thankyou
