This thread is for discussion only on the insulating aspects of the inner and outer tubes.
Outside tubes was encased in delrin and was open at the top and bottom.
the inner tube fixed inside the outer tube of course, is the negative tube and will gain a white coating that seems beneficial and will further restrict current.
There are many materials and ways to insulate the outside of the outer tube and NOT THE INSIDE OF THE OUTER TUBE of course since that contacts the water and needs enough conductivity to pull electrons from the freed up electrons from water ionization, which the electron extraction circuit (EEC) sucks from the water on the OFF pulse.
The inner tube 'could' be insulated beyond the calcium oxide coating. Further discover needed.
