would not it be better to use nitrogen instead dirty exhaust fumes? Therefore I wanted to use copper. so instead of Pantone Reactor I could use VN ozone generator and exhaust fumes? it is complicated to do and starts the engine. I wanted to avoid using oil and engine theory bazijev. thank you
The mysterious technology of Stanley Meyer
well I hear many people are running their diesel engines on burnt oils.. cooking oils e.t.c. I even read it on an article of a magazine ..
Combustion of fat and vegetable oil derived fuels in diesel engines
The potential of using vegetable oil fuels as fuel for diesel enginesLast edited by tachyon; 09-14-2013, 07:00 PM.The pure in heart will see the light.
Originally posted by tutanka View PostYes.. this is called normally electron beam and I agree with you photons or electrini crack molecules and .. you need also temperature.
But for run an engine properly using water you need also an little amount of carbon .. all togheter..
thanks for read me
I know we were looking at oil, but what of other sources.Last edited by adam_mizer; 09-14-2013, 08:19 PM.
an answer for all..
Originally posted by adam_mizer View PostCan carbon come from trace amounts sodium carbonate, oaxalic acid, or CO2, mixed with water?
moneys using an small amount of hydrocarbon..
Please...
Study with attention the PMC naudin diagram and you understand that simply you can modify this reactor tube (adding an new metal catalyst inside) reaching the success without using complicated electronic circuits and do not use an large amount of electrical energy as the Bingofuel The BingoFuel Reactor v1.0 by JL Naudin obtaining every COH2 as final fuel.
If you check better this diagram is very similar (or the same) of the Stanley Meyer concept.. water, exaust gas, air (and an small amount of hydrocarbon).Last edited by tutanka; 09-18-2014, 01:34 PM.
Originally posted by wolf234 View Postwould not it be better to use nitrogen instead dirty exhaust fumes? Therefore I wanted to use copper. so instead of Pantone Reactor I could use VN ozone generator and exhaust fumes? it is complicated to do and starts the engine. I wanted to avoid using oil and engine theory bazijev. thank you
All is connected..
The PMC diagram is the semplicity and how with an smaller amount of hydrocarbon (also vegetable oil can be useful) you can power an engine..
Originally posted by wolf234 View Postthank you I will work on the project. few grams of Catalysts
temperature, and high-voltage variable-on tubes. hho
What is the real function of smaller amount of oil?
All reactions are based on chemical..
What is for you the real chemical process that appear inside the reactor??
Only if you answer correctly you can build the properly device..
Analyze better..
FORGET ALL THAT IS WRITTEN INTO THE STANLEY MEYER PATENTS BECAUSE THE TRUTH IS DIFFERENT AND MUCH SIMPLER IF YOU WANT AN WORKING DEVICE!!Last edited by tutanka; 09-15-2013, 09:04 AM.
The base processor GEET is a heat exchanger in which a substantial portion of the heat from the exhaust gas transferred to the suction vapor . These are in the chamber using the venturi effect subsequently exposed not only temperature but also high vacuum , and quickly becomes superheated steam. Heavy molecules of carbon and other compounds are cracked into smaller . The higher the vacuum chamber, the faster this process occurs .
Physical progress can be described as controlled lightning. When they clash of hot and cold masses generated electric charges . The masses of ionized air radially spread and emit colored light . Optimum process is achieved when the resulting electromagnetic field has both radial and longitudinal components. Due to this field , which itself creates and stabilizes no problem with random plasma cloud formation .
Length plasma chamber depends on the fuel used . Exotic mix of 20 % battery acid (H2SO4 ) and 80 % salt water needs a shorter plasma zone than the need to use oil. The processor requires no additional energy input .
So much for Paul Pantone .
This, and other evidence published to this technology leads me to the following considerations.
Notice an interesting feature . All existing plasma generators from the system described above differs in that the fuel supplied to them under pressure. In GEET but used a vacuum whereby the light reaches the separation of H + from the heavier molecules OH ! Thus, the same effect as the JC .
I believe that hydrocarbon or other compound in the reaction vessel is not required when the reactor předžhaví normal operation on petrol or gas. The warm-up system is not to be more than 10 seconds . Incandescent (plasma ) chamber has a place in the first part of the exhaust , just for the collector . Nor is it necessary bubbling of exhaust gases with water at this point could be successfully used ultrasonic fog machine .
Immediately after the attack formation of plasma ignition must be redeveloped into a position in which it burns well in advance, as well as the JC . The electronically controlled ignition is not a problem . GEET does not move when you run out of workable mixture of hydrocarbons vytvářejísí town gas , methane, and so on. The real water plasma , however, when set this fuel can not detonate at all !
You must use the correct form of rods, tubes may be made of non-magnetic stainless steel. Magnetized prevents the Curie temperature
boundaries . An electric field is created when cracking of molecules in the gap. The inserted rod should contact for better par protracted venturi area could possibly be twisted prism with progressive pitch "thread " . At the start point, the end of the flat end with sharp edges. When this pattern is behind the bars to reverse flow , which together with the magnetic field captures heavier OH , while light molecules of H + are spread apart and drawn into the intake . Thus , a mutual separation of charge. Inlet connection might have had a ceramic insert for electrical separation from the generator powered unit reactor rod stainless steel thank youLast edited by wolf234; 09-15-2013, 01:24 PM.
Originally posted by wolf234 View PostThe base processor GEET is a heat exchanger in which a substantial portion of the heat from the exhaust gas transferred to the suction vapor . These are in the chamber using the venturi effect subsequently exposed not only temperature but also high vacuum , and quickly becomes superheated steam. Heavy molecules of carbon and other compounds are cracked into smaller . The higher the vacuum chamber, the faster this process occurs .
Length plasma chamber depends on the fuel u8sed . Exotic mix of 20 % battery acid (H2SO4 ) and 80 % salt water needs a shorter plasma zone than the need to use oil. The processor requires no additional energy input .
Ok some generic informations (yours?) ...but what is the function of smaller amount of hydrocarbons (oil,gasoline, diesel,etcc)??
You write about electric field. . Make plasma isnt simply as make electricity.
Please explain chemically what appear inside the reactor and what type of fuel is produced because we are talking to Power an engine ..Last edited by tutanka; 09-15-2013, 04:29 PM.
hello. Some of my certain general. Tube can be graphite. might think that the oil of the electron donor. discharge gives off positively electrino - neutrino. or are at cracking release electrons from the molecular decay - gas is bingofuel. possible electron avalanche as stated. It's almost not using dirty but also works urea fuel probably not move
Originally posted by wolf234 View Posthello. Some of my certain general. Tube can be graphite. might think that the oil of the electron donor. discharge gives off positively electrino - neutrino. or are at cracking release electrons from the molecular decay - gas is bingofuel. possible electron avalanche as stated. It's almost not using dirty but also works urea fuel probably not move
oil is tranformed in other molecule or is burned inside the reactor tube?
Adding HHO probably unnecessarily. oil is decomposed to carbon monoxide - water to hydrogen helped by induction heating and fogger would not it be better to use the air intake from the heating positiv ionizer, 1 l of HHO gas, plasma ignition?Last edited by wolf234; 09-15-2013, 08:17 PM.
Originally posted by wolf234 View PostAdding HHO probably unnecessarily. oil is decomposed to carbon monoxide - water to hydrogen helped by induction heating and fogger
