Hi folks,
this is my very first post here at the forum. dealing with new energy themes here maybe we can support one another to speed up progress.
for some time now Iīm working on Stan Meyer replication and some of my fellows are doing some work on Bob Boyce replication.
Searching for a flexible pulse generator in the past some time ago I have found a single chip solution that really fits best to my experiments.
It has 3 or 4 independent pulse channels from 0 to 100 kHz and above.
All parameters can be adjusted using a Windows Client Interface. thatīs much more exact and replicable than using those large scale potentiometers found in all those discrete hardware pulser solutions.
You can download a free operational trial version at https://www.dropbox.com/s/d8wd7coxux...Gen_demo_e.pdf.
The little uC circuit Iīm using has gating, pll lock feature and 2 or more channels can be bound together to realize phase shift between the channels.
with mulit-phase-multi-channel output
https://www.youtube.com/watch?v=BdgJMh9hTQw
with fibre optics connections
as an example I can create a pulse train like
"endless loop applying 12 pulses with 10 ms on and 20 ms off each followed by a gating phase of 300 ms"
or
"endless loop applying 5 pulses with 20 ms on and 20 ms off followed by 8 pulses with 10 ms on and 15 ms off"
up to 8 pulse sequences can be defined in a line.
I can define a number of pulses on demand:
"1000 times ( 5 pulses with 5 ms on and 8 ms off followed by gating of 10 ms) and then stop"
In addition I can bind 2 to 4 channels together:
letīs say I want to create those Boyceīs frequecies at 42.8 kHz, 21.4 kHz and 10.7 kHz.
I can start them synchronized and make slight time changes to create phase shifts on demand.
For example:
create channel 1 pulse sequence: "endless loop at 42.8 kHz duty cycle 50%, syncronized"
create channel 2 pulse sequence: "endless loop at 21.4 kHz duty cycle 40%, syncronized"
create channel 3 pulse sequence: "endless loop at 10.7 kHz duty cycle 30%, syncronized"
once started each frequency parameter can be immediatly changed by a click. frequencies stay phase shift locked.
I can also create 3 frequencies phase shifted:
create channel 1 pulse sequence: "endless loop at 42.8 kHz duty cycle 50% phase shift 0 degree, syncronized"
create channel 2 pulse sequence: "endless loop at 42.8 kHz duty cycle 50% phase shift 120 degree, syncronized"
create channel 3 pulse sequence: "endless loop at 42.8 kHz duty cycle 50% phase shift 240 degree, syncronized"
there are 1000s of frequency variations possible.
Update: newest version of 08-20-2014 supports frequency sweep and pulse frequency to > 3 MHz.
I can replicate Stan Meyer 8XA, 9XA, PLL lock pulsers (with frequency search), all of Boyceīs 3 channel uC or discrete pulsers, for each uC up to 4 channels.
And itīs all within that singe chip matchstick sized solution :-)
Bang for the buck!!!
you can get a brief description and watch a photo at pgen.
I also use fast isolated electronic switches, up to 1200V / 60A (depending on what is needed in my experiments).
Letīs have fun with our experiments!
or
For example:
