Hi all
Since nobody has started a thread about joecells or simple electrolysers, I will. I have watched many many videos about elecytrolysis, joecells, HHO torches and so on. I have experimented with joecells, although this has almost nothing to do with electrolysis since it is an orgone or aether accumulator, there is some concepts there that I will use for my electrolyser. So my goal is to make an medium power HHO torch to investigate the flame and some properties of the water that is produced by burning the HHO gas. Of course I want to do this as efficient as I can. I studied through all the electrolysis manuals on Practical Guide to Free-Energy Devices
And finally came up with such electrolyser design:
There are six separated compartments in this electrolyser, this way I can connect the plates in series and power it all from 12v, that would be a little less than 2V per compartment. Since the gas production goes up if the voltage is increased from 0-1.24V, above that voltage all the energy goes into waste in the form of heat. And heating is a big problem in many of those youtube video electrolysers. The theory is that it makes no difference in gas production if you are using 1.24V and 10 Amps or 1000V and 10 amps. So we must use the nearest voltage possible to the 1.24v, this increases the efficiency and eliminates the heat problem. Also my experience with joecells suggested me to use also some neutral plates in each compartment, since this reduces the amp draw and does not affect the gas production. Also these neutral plates put a big portion of radiant potential in the water and gas, basically the gas becomes more powerful. Joe says that with neutral plates a new gas is formed in the electrolyser, that has some radiant properties along the ordinary HHO properties. Maybe that is the radiant energy gaseous fluid that manifests itself in form of HHO gas and makes ir more powerful, I don't know
So basically the plates (150x200x1mm) in each compartment are placed in the following manner: positive, neutral, negative, neutral, positive. This way I can produce gas form both sides of the negative plate. The electrolyser outer walls are made of 8mm thick plexyglass and the wall between compartments is 5mm thick. They are glued together with dichlorethane. Here are some more pictures:
I made some simple plate spacers form plexyglass. This way I can simply slide the plates in each compartment easily and the spacers hold them 5mm apart of each other and about 10mm from the bottom so that the water can flow around.
