Suggestions
Hi!
Perhaps you have leakage somewhere, gas flows out somewhere before it gets to bubbler. Another fault can be that electricity - amperes are running through electrolite and bypass the plates, as an example as smacks booster - where multiple plates are just immersed in water, and electricity flows not only in path between plates but also around them, via electrolyte. Also, it will be nice if you buy some cheap dc ampere meter with shunt on ebay, to measure how much amp draw eats the hho generator.
If gen eats a lot amps, and gets warm, than it seems electricity flows through electrolyte making short around plates. But electricity must flow through plates and only electrolyte layer between plates, not around all water that are inside hho gen!
Also, i highly recomend to use koh and distiled water.
Try different density of koh solution, and watch amps and production.
i had the same problem with my earlier hho gen designs - but new hho gen design, as Kumaran and Jetijs did, newer made any problems, the only thing i was ought to do is just fill it with right % koh solution
So good luck, and share results and efficiency table!
Hi!
