Neutral plates
I see so manp people use neutral plates but they dont work unless the space between the plates is issolated from the next space. If you have neutral plates jsut wide open in a tank of liquid they wont work then you have a plus plate and a minus plate seperated by a wide distance with a bunch of metal in between. the electricity is mostly going to go around the neutral plates.
They need to be seperate cells to be effective, just think of a stack of batteries, the plus connects to the minus of the next one and so on. they are in series.
So to make teh neutral plates work you need to have the plates go all the way to the side of the housing and seal each compartment of water off from the next , then the current is forced to go through the neutral plates and then they become actualy active plates. So if you have 6 compartments of water between a bunch of plates and the positive on one end and the negative on teh other then each cell gets 2 volts. then you get more cells with the same current draw and more gas output.
So if you dont issolate each plate space from the other then neutral cells are counter productive, then you are better of connecting each alternate plate to the power for maximum gas and forget the neutral plates.
