spark mechanism
Hi Boguslaw,
Now you're talking!
You mentioned super short connections...YES! The coil ideally would be screwed to the top of the spark plug with the HV diode connected directly to that connection and the rest of the connection with large size copper wire making straight lines and 90 degree angles and no curves.
You said: "As I said there is NO energy left in cap after HV discharge! That energy what is used at LV arc is already stored somewhere else ... in coil"
The coils do store the potential, however, this would have to be proven. There are some easy tests to do to see what is coming from the coil besides what is leaving the HV output.
What S1R is doing is different. With this particular circuit we are looking at may be enhanced by adding power through an inverter, variac, etc... but that is a totally separate issue.
The point being, the cap all by itself as the only input does give the effect.
It may be a good idea for anyone to note that while there is HV leaving the secondary, the HV will force the HV diode to remain CLOSED AT ALL TIMES until there is no more HV on that side of the diode. That means while the diode is CLOSED, there is nothing moving through it from the LV side.
Is the effect from power stored in the coil? More probable than LV going through diode from the cap for obvious reasons. However, the power would be there anyway with or without the HV diode and the effect only happens with the diode.
Hi Boguslaw,
Now you're talking!
