Water Sparkplug
This topic is closed.
  • non fouler plug
    Originally posted by Redmeanie View Post
    Ha! The Non Fouler is exactly what Im using! Its scary that some of us are on that Close of a WavePath! Length or whatever....
    Nice! I was thinking of using rubber tubing as an insulator with ID same as OD of middle rod and OD of tube same as ID of the non-fouler. If it could be set in there to withstand the explosion, might be a good cheap homebrew water injector plug.
    If the tube had some kind of 1 way valve going to an HHO and water mist supply, the vacuum would suck it right into the combustion chamber on the down stroke. I think the air intake could probably be blocked off totally or almost totally.
    RPX & MWO http://vril.io
      Im looking at doing this with some High Pressure Stainless "Fogging Nozzles" with .012 orifices (I have .008 also if more break down is needed), Machine threaded to an actual Fuel Injector. I don't think back pressure will come into play to much here. Then Maybe a 2 Part Industrial Epoxy or JB weld around the Nozzle to insulate it from the Non Fouler Case. I have a spare set of Injectors that Im going to use, and it looks like I may be able to thread the seat so it will all screw together.....At Least thats what Im Hoping!
      RedMeanie
      • great idea!
        I really like that idea! You'll get more bang out of it with a simple modification I'll show soon.
        • Hi Peter, Aaron and everyone.
          It is nice to see all the activity and enthusiasm here compare to my original topic I started at Overunity, which seems to be dying now. I think people can get too easily distracted by dangling carrots and soon forget they were holding one. My life experience has tough me that moving from one thing to the next will not give you any more! in fact I found those who stuck to one thing actually got more.
          I do support the idea of different topics which should help keep focus to those who wish to get a deeper understanding of a specific circuit or an effect before moving on to something else.
          Now about the Water Power circuit. I can see that many are wondering how I got the circuit to work with a 2uf capacitor. I was able to do this but the circuit was different then from now. Earlier the + of the bridge would stay connected to the LV side with 10 x 1N5404 in series (see below attachment) and the cap was connected only to the + of the coil and not to the LV side. The circuit work this way and I also found that I was able to get it to go in a kind of hyper mode when I used a variac and isolation transformer and went over 140 volts to 160 volts. This video: YouTube - Ganga Shakti - Water Power Test 2 is demonstrating this. Now be very careful if you get it to this! as the light is full of UV and you should not look at it without eye protection. You will be able to tell once it gets there as the spark sound different and it's like looking at the Sun. Also the interesting part is you would think it would get hot but it doesn't, maybe about at body temperature.
          @Peter L, I would like if you can try this setup since you have the equipment needed and I would really like know what you think of this Hyper Spark effect.
          Luc
          P.S. just to let you all know, my name is pronounced just like Luke but I write it in French since that is my first language.
          • amplify the water spark
            Water Sparkplug Amplifier Method.
            I remember a vid by Jetijs and some others had some enhanced effects and am not sure if this is what is is but this came to me by glancing at some S1R speculation diagrams. Vid avail in few minutes.
            • thanks Luc!
              Thanks for the post Luc. What I see happening with enthusiasm for some is they want to immediately drive their car on water without care about what the effect is. If it is known, then it can be manipulated for more enhancements. I just posted a diagram of something I tried and a video is uploading as I type this.
              • spark comments
                Luc, LOL!!! What a great synchronicity. What I posted is essentially the same as what you showed at the same time just about!! Except that I put a cap in parallel with the bridge....I also can turn the power supply off as long as that cap is charged, and I get the effect...it isn't about low voltage/high current.
                I understand what you're doing. The HV goes backwards through the HV diode for just a very very small brief moment seeking ground...then the diode shuts off. That causes the voltage potential at high inertia to slam against the diode forcing it 90 degrees away from the wire...that is the primary cause of the main effect. It uncondenses the heaviside flow over the wire and causes it to puff up and take up more cubic volume of space in order to allow for more potential to be extracted from it. This is plain and simple the effect of what the Gray Tube does.
                Anyway, once you get that primary effect and that jumps the gap, that is a plasma spark but a radiant plasma that is a cold plasma caused by a very specific way...it drops resistance over the gap and a photoflash cap across the gap with a diode will enhance the spark (with power supply off just to prove that)....and that discharge of low current and about 160v from the little cap will enhance the spark. That is a normal capacitive discharge following a modified impulse and that is NOT normal hv spark crossing that gap. The voltage potential was moving at 90 degrees to the wire..away from the wire.
                Anyway, the focus on this in this forum will continue to grow I believe. Jetijs and Redmeanie are working on getting Jetijs's car to run on this method or at least get the door open on moving forward to the optimum solution.
                Others are working on this effect and Peter and I in our very limited time are interested in studying the effect. My claims of what is happening are educated guesses...pretty good ones I believe and I have reason to believe them. But the fact remains that the HV does see an open diode on that HV diode the moment it discharges and the HV diode then slams shut. Modified HV pulse goes over gap and that is the effect....if there is other stored potentials that can follow it, then fine that is good, but just to know...that isn't what causes the primary effect.
                • new spark vid of enhanced effect by capacitor
                  YouTube - Aaron's Water Spark Plug Amplifier
                  Camera just doesn't do it justice...the enhanced spark is extremely bright and the noise is deafening. I will have to bust out my good camera for these vids.
                  Please note, my assistant cap...a 2nd cap charged by bridge from variac...then turn OFF variac...will still give enhanced effect...high current following HV isn't needed...the 2nd cap is still a very low current pulse at about 160 volts. Anyone can verify this, please see my notes posted a few posts ago.
                  • good vid, modifications are growing .keep going big guy!
                    “Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
                    Nikola Tesla
                    http://www.imhotepslab.com
                    • Aaron,
                      Your circuit is now in close relationship with the one from Us patent 006553981.
                      Except one thing : a diode on HV path.
                      I attached your schematic with added diode. Would be nice to test it.
                      My theory is still the same: capacitor discharge is occuring all the time (capacitor and coil secondary make a closed loop) but it is stopped by large self-induction of coil . High frequency oscillation is generated here in coil and is jumping between coil and cap till HV discharge is forcing it to escape.
                      High voltage RF superimposed on quite a nice amount of electrons is a source of radiant energy.
                      Anyway I expect such a diode as in patent to limit capacitor discharge and so also the oscillations and final effect because diode as placed here acts against capacitor discharge current. However if cap discharge can flow in both directions like AC wave then diode just limit effect to 1/2 of original power spark.
                      • Awesome.....Ive been up all night working on this...God! I think Im going to "Awake" Myself to Death! Even when I sleep I dream about this circuit! Am I going crazy or are there others out there!
                        RedMeanie
                        • Sorry, I meant this patent : Dual-mode ignition system utilizing traveling spark ignitor - Patent 6553981
                          • Originally posted by Redmeanie View Post
                            This is the inventor disease I suppose! Maybe we all need Imhotep's radiant booster!!
                            http://blog.hexaheart.org
                              Hi Redmeanie, interesting you mention God and Dream. I also dream about the circuit and an engine running on water most of the nights. Also about God, Aaron had asked me how I found this circuit and this was my reply.
                              Reply to Aaron:
                              I think you are the first one to ask me about how I came to this circuit. It is not my doing!... it is God's Grace. I ask for His help and guidance to find something that could help just days before finding it. The circuit came the day after I posted a reply to S1R on his Yahoo Group. What I was trying to do is to get my inverter to short circuit at the spark plug once the HV of the coil jumped the gap. I had so many components to try to do this and at one point I noticed that the spark was strong and wondered what part of the circuit was doing this ... so I started eliminating one thing at a time to find the cause and eventually found this simple circuit.
                              Luc
                              @Everyone, there are many coincidences going on here!... just like the message I posted above at 4am while Aaron was doing the same test. I can see that some of you have picked up on this also, which is good. The more we work together and share our findings the more we will receive.
                              There is an upper Hand at work here and we can all receive the Grace if we work together. Do not entertain any selfish thoughts and follow that inner voice, it will guide you.
                              Luc
                                Yes, Red.
                                The same here. already three nights in a row
