Spark Plug photos
Hi Aaron,
I tried pulsing the coil with a 12V, and no sparks. That is kind of strange because it should work since that is how it is done inside an engine. The only difference is that the pressure is different. May be that is why.
In the CDI mode, I tried using 4.7uF and 10uF for the primary capacitor, and both worked great. 10uF seems to be a little better with less miss firing at higher frequency.
I have attached 2 photos of my spark plugs. One is almost new (only had about 30 seconds of firing), and the other is after may be a total of 40+ minutes of firing. You can see the difference. I did enlarge the gap of the burnt plug to a wider one. The burning effect is also evident in the new plug after only about 30 seconds of firing. The heat generated apparently is extremely hot. How will it affect the engine? Will it burn a hole through the cylinder head? Will the high temp ignite water?
